Daniel Santos
Newbie level 1
- Joined
- Jul 29, 2014
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 20
Hello to all,
I need help to find a switched line phase shifter high attenuation problem.
I designed a phase shifter with the Switched Line topology. The requirements are:
- Center frequency @ 2.42 GHz;
- 4-bits: 22.5; 45; 90 and 180 degrees;
- low insertion loss and high isolation;
- Built with microstrip line and SPDT switches from HITTIE (model HMC545E);
- Use of the RF Module from COMSOL for simulation;
I have already designed the complete microstrip line (50 Ohm on duroid 5880 Er=2.2) on COMSOL, so I moved on to implementation. 1st stage of Implementation I have made 1 bit with 90 degrees for a test and it works fine (DUT in Vector Network Analyzer from Rohde & Schwarz model ZB4):
- Insertion Loss: 0.8 dB for Ref Line and 1 dB for delay line;
- S11: < -12 dB;
- Difference of phase: 87 degrees between lines;
- Others single bit phase shifters worked fine (22.5, 45 and 180º).
The problem description:
When I build 2 bits together (22.5 and 45 degrees) does not work:
- Insertion Loss in best case is - 4.2 dB and in worst case -8.3 dB;
- S11: in best case is - 12 dB and in worst case is -3 dB;
- Phase Difference between lines is bad for some cases and correct for another’s;
When similar circuits with the same SPDT switches are said to work fine in several papers. The only difference is in microstrip line, the paper use CPW line.
So I need help to find my problem, unfortunately the COMSOL does not have active components libraries like SPDT or pin diodes so I could simulate. I don’t have many background in the RF and Microwave and all I learn until now, was alone reading some books and IEEE articles.
I think my problem is reflections due to some bad adaptation between lines and SPDTs??
Here is the picture of my design, where do you think I did a mistake?
https://obrazki.elektroda.pl/2784486900_1408963979.png
- S11: < -12 dB;
