neazoi
Advanced Member level 6
- Joined
- Jan 5, 2008
- Messages
- 4,157
- Helped
- 13
- Reputation
- 26
- Reaction score
- 15
- Trophy points
- 1,318
- Location
- Greece
- Activity points
- 37,198
Hello, I have made this small impedance bridge **broken link removed**
The DC out is taken from the negative terminal of the diode. The positive terminal is grounded with a resistor. This outputs a negative output voltage.
I has wondering, if these connections could be reversed so I can get a positive voltage output. That is, take the DC out from the positive of the diode and ground the negative with a resistor?
