globalone
- Joined
- Dec 15, 2011
- Messages
- 7
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,337
Hello,
I am building a fast switch driver circuit . Switching speeds are similar to the bipolar design.
The circuit provides 35nSec rise and fall times. This circuit will turn the switch on and off within 50nSec.
My target is to have faster speed for Turn-On/Turn-Off . 35nSec would be okay for the T-On/T-OFF , but I want to reach between 15nSec ~ 30nSec.
Do you think that BSS84DW (**broken link removed**) can be replaced with NDC7003P or NDS9948 ?.
What speed would i reach If I am going to use NDC7003P or NDS9948 ?.
https://www.fairchildsemi.com/ds/ND/NDC7003P.pdf
https://www.fairchildsemi.com/ds/ND/NDS9948.pdf
I want to provide the circuit with a negative supply between -40V to -50V.
I appreciate your help
Regards,
Ghassan
Hello,
Regards,
Ghassan
