hi there ca anyone help me with this code please i have written up the major parts namely thd functions of the code but am having dificulties with the struct and enum setup can some one help me set it up please;;;;;;;;;
//////**********Chamwasu Musa Gali******
//////*********Advanced Stepper Motor Control Codes*******
//////********Final Year Project Codes******************
//////********BEng Electrical and Electronics Engineering******
//////********University of Hertfordshire*******************
#include <htc.h>
#include <pic.h>
#define stepcnt 300 //max number of steps
#define _XTAL_FREQ 20000000
void Run_Motor1_cw(void);
void Run_Motor2_cw(void);
void Accel_Motor1_cw(void);
void Deccel_Motor1_cw(void);
void Accel_Motor2_cw(void);
void Deccel_Motor2_cw(void);
void Run_Motor1_ccw(void);
void Run_Motor2_ccw(void);
void Accel_Motor1_ccw(void);
void Deccel_Motor1_ccw(void);
void Accel_Motor2_ccw(void);
void Deccel_Motor2_ccw(void);
enum MotorID {Motor1, Motor2};
enum Bool {False, True};
enum Direction {Clockwise, Anticlockwise};
int iSpeed=0;
struct Motor
enum MotorID MotorName;
enum Direction ActiveDirection;
enum Bool Active;
int iMotorSpeed;
int fMotorSpeed;
void main(void)
struct Motor PrimaryMotor, SecondaryMotor;
PrimaryMotor.MotorName=Motor1;
SecondaryMotor.MotorName=Motor2;
PrimaryMotor.iMotorSpeed=0;
SecondaryMotor.iMotorSpeed=0;
PrimaryMotor.ActiveDirection=Clockwise;
SecondaryMotor.ActiveDirection=Clockwise;
PrimaryMotor.Active=True;
SecondaryMotor.Active=False;
//this is an example to check if Primary motor is active!!
if(PrimaryMotor.Active ==True)
//putstatments to drive primary motor
if(PrimaryMotor.ActiveDirection==Clockwise)
Run_Motor1_cw();
else
Run_Motor1_ccw();
if(SecondaryMotor.Active ==True)
//put statments to drive secondary motor
if(SecondaryMotor.ActiveDirection==Clockwise)
Run_Motor2_cw();
else
Run_Motor2_ccw();
if(PrimaryMotor.iMotorSpeed==1)//if final motor speed is select accelerate motor to speed up
Accel_Motor1_cw();
else
Accel_Motor1_ccw();
if(SecondaryMotor.iMotorSpeed==1)
Accel_Motor2_cw();
else
Accel_Motor2_ccw();
if(PrimaryMotor.fMotorSpeed==1)//if iniital motor speed is select decelerate motor to slow down
Deccel_Motor1_cw();
else
Deccel_Motor1_ccw();
//if(SecondaryMotor.fMotorSpeed==1)
/*if(SecondaryMotor.ActiveDirection==Clockwise)
Deccel_Motor2_cw();
else
Deccel_Motor2_ccw();*/
/*if(PrimaryMotor.iMotorSpeed == 1)
//statements to speed up motor
if(PrimaryMotor.ActiveDirection==Clockwise) //&& PrimaryMotor.ActiveDirection=Clockwise)
Accel_Motor1_cw();
else
Accel_Motor1_ccw();
if(PrimaryMotor.iMotorSpeed == 0)
Deccel_Motor1_cw();
else
if(SecondaryMotor.iMotorSpeed == 1)
if(SecondaryMotor.Active==True)
Accel_Motor2_cw();
else
Accel_Motor2_ccw();
if(SecondaryMotor.iMotorSpeed==0)
Deccel_Motor2_cw();
else
//You will need to write a function for the speed control of the motors.
//You will also need to write statments to assign the properities of the Motor structure....
//You will need to connect the IR reciever to a port of the PIC and read the data that come in.
//for example if Motor selection is pressed and you need to know which pin in the port is activated.. read it and toggle the motors states.... ie
//if you want to activate Primary motor
// PrimaryMotor.Activate=True;
// SecondaryMotor.Activate=False;
TRISA = 0xFF; //SET PORT A AS INPUT
PORTA = 0; //INITIALISE PORTA AS 0
TRISB = 0xFF; //SET PORT B AS INPUT PORT
PORTB = 0; //INITIALISE PORT B AS 0
TRISC = 0x00; //SET PORT C AS AN OUTPUT PORT
INTE = 1;
INTF = 0;
INTEDG = 1;
GIE = 1;
while(1)
Run_Motor1_cw();
__delay_ms(3000);
Run_Motor2_cw();
__delay_ms(3000);
void Run_Motor1_cw(void) //function to run motor 1 at constant speed
int b;
PORTC = 0x32; //reset motor phases to initial position 0101 and light up led to indicate motor 1 is active and wait for the step signal
__delay_ms(50);
for(b=0;b<=stepcnt;b++) //loop to step 100 times running motor1
PORTC = 0xB2;
__delay_ms(250);
PORTC= 0xB3;
__delay_ms(250);
void Run_Motor2_cw(void) //function to run motor 2 at constant speed
int d;
PORTC = 0x52; //turn on led to indicate motor 2 is about to start running and wait for the step signal
__delay_ms(50);
for(d=0;d<=stepcnt;d++) //loop to run motor 2 for 100 steps
PORTC = 0xD2;
__delay_ms(250);
PORTC = 0xD6;
__delay_ms(250);
void Accel_Motor1_cw(void) //function to accelerate motor 1
int x;
PORTC = 0xB2;//delay tables to accelerate motor 1
__delay_ms(250);
PORTC = 0xB3;
__delay_ms(250);
PORTC = 0xB2;
__delay_ms(250);
PORTC = 0xB3;
__delay_ms(250);
PORTC = 0xB2;
__delay_ms(220);
PORTC = 0xB3;
__delay_ms(220);
PORTC = 0xB2;
__delay_ms(220);
PORTC = 0xB3;
__delay_ms(220);
PORTC = 0xB3;
__delay_ms(200);
PORTC = 0xB2;
__delay_ms(200);
PORTC = 0xB3;
__delay_ms(200);
PORTC = 0xB2;
__delay_ms(200);
PORTC = 0xB3;
__delay_ms(170);
PORTC = 0xB2;
__delay_ms(170);
PORTC = 0xB3;
__delay_ms(170);
PORTC = 0xB2;
__delay_ms(170);
PORTC = 0xB3;
__delay_ms(140);
PORTC = 0xB2;
__delay_ms(140);
PORTC = 0xB3;
__delay_ms(140);
PORTC= 0xB2;
__delay_ms(140);
PORTC = 0xB3;
__delay_ms(100);
PORTC= 0xB2;
__delay_ms(100);
PORTC= 0xB3;
__delay_ms(100);
PORTC= 0xB2;
__delay_ms(100);
PORTC = 0xB3;
__delay_ms(60);
PORTC =0xB2;
__delay_ms(60);
PORTC = 0xB3;
__delay_ms(60);
PORTC = 0xB2;
__delay_ms(60);
PORTC = 0xB3;
__delay_ms(30);
PORTC = 0xB2;
__delay_ms(30);
PORTC = 0xB3;
__delay_ms(30);
PORTC = 0xB2;
__delay_ms(30);
for(x=0;x<=stepcnt;x++) //loop to maintain final speeed after delay table implementation for 100 steps
PORTC = 0xB2;
__delay_ms(15);
PORTC = 0xB3;
__delay_ms(15);
void Deccel_Motor1_cw(void) //function to decelerate motor 1
int y;
PORTC = 0xB2; //delay tables to decelerate motor 1
__delay_ms(15);
PORTC = 0xB3;
__delay_ms(15);
PORTC = 0xB2;
__delay_ms(25);
PORTC = 0xB3;
__delay_ms(25);
PORTC= 0xB2;
__delay_ms(25);
PORTC = 0xB3;
__delay_ms(25);
PORTC= 0xB2;
__delay_ms(60);
PORTC= 0xB3;
__delay_ms(60);
PORTC= 0xB2;
__delay_ms(60);
PORTC = 0xB3;
__delay_ms(60);
PORTC = 0xB2;
__delay_ms(80);
PORTC = 0xB3;
__delay_ms(80);
PORTC = 0xB2;
__delay_ms(80);
PORTC = 0xB3;
__delay_ms(80);
PORTC = 0xB2;
__delay_ms(120);
PORTC = 0xB3;
__delay_ms(120);
PORTC = 0xB2;
__delay_ms(120);
PORTC = 0xB3;
__delay_ms(120);
PORTC= 0xB2;
__delay_ms(140);
PORTC = 0xB3;
__delay_ms(140);
PORTC = 0xB2;
__delay_ms(140);
PORTC = 0xB3;
__delay_ms(140);
PORTC = 0xB2;
__delay_ms(140);
PORTC = 0xB3;
__delay_ms(160);
PORTC = 0xB2;
__delay_ms(160);
PORTC = 0xB3;
__delay_ms(160);
PORTC = 0xB2;
__delay_ms(180);
PORTC = 0xB3;
__delay_ms(180);
PORTC = 0xB2;
__delay_ms(180);
PORTC = 0xB3;
__delay_ms(180);
PORTC= 0xB2;
__delay_ms(180);
PORTC = 0xB3;
__delay_ms(200);
PORTC= 0xB2;
__delay_ms(200);
PORTC= 0xB3;
__delay_ms(220);
for(y=0;y<=stepcnt;y++) //loop to maintain final speed after deceleration table implentation
PORTC = 0xB2;
__delay_ms(250);
PORTC = 0xB3;
__delay_ms(250);
void Accel_Motor2_cw(void) //function to accelerate motor 2
int m;
PORTC= 0xD2; //delay tables to accelerate motor two
__delay_ms(250);
PORTC = 0xD6;
__delay_ms(250);
PORTC = 0xD2;
__delay_ms(250);
PORTC = 0xD6;
__delay_ms(250);
PORTC = 0xD2;
__delay_ms(220);
PORTC = 0xD6;
__delay_ms(220);
PORTC = 0xD2;
__delay_ms(220);
PORTC = 0xD6;
__delay_ms(220);
PORTC = 0xD2;
__delay_ms(200);
PORTC = 0xD6;
__delay_ms(200);
PORTC = 0xD2;
__delay_ms(200);
PORTC = 0xD6;
__delay_ms(200);
PORTC = 0xD2;
__delay_ms(170);
PORTC = 0xD6;
__delay_ms(170);
PORTC = 0xD2;
__delay_ms(170);
PORTC = 0xD6;
__delay_ms(170);
PORTC = 0xD2;
__delay_ms(140);
PORTC = 0xD6;
__delay_ms(140);
PORTC = 0xD2;
__delay_ms(140);
PORTC = 0xD6;
__delay_ms(140);
PORTC = 0xD2;
__delay_ms(100);
PORTC= 0xD6;
__delay_ms(100);
PORTC= 0xD2;
__delay_ms(100);
PORTC= 0xD6;
__delay_ms(100);
PORTC = 0xD2;
__delay_ms(60);
PORTC =0xD6;
__delay_ms(60);
PORTC = 0xD2;
__delay_ms(60);
PORTC = 0xD6;
__delay_ms(60);
PORTC = 0xD2;
__delay_ms(30);
PORTC = 0xD6;
__delay_ms(30);
PORTC = 0xD2;
__delay_ms(30);
PORTC = 0xD6;
__delay_ms(30);
for(m=0;m<=stepcnt;m++) //loop to maintain final speeed after delay table implementation for 100 steps
PORTC = 0xD2;
__delay_ms(15);
PORTC = 0xD6;
__delay_ms(15);
int n;
PORTC = 0xD2; //delay tables to decelerate motor 2
__delay_ms(15);
PORTC = 0xD6;
__delay_ms(15);
PORTC = 0xD2;
__delay_ms(25);
PORTC= 0xD6;
__delay_ms(25);
PORTC = 0xD2;
__delay_ms(25);
PORTC= 0xD6;
__delay_ms(60);
PORTC= 0xD2;
__delay_ms(60);
PORTC= 0xD6;
__delay_ms(60);
PORTC = 0xD2;
__delay_ms(60);
PORTC = 0xD6;
__delay_ms(80);
PORTC = 0xD2;
__delay_ms(80);
PORTC = 0xD6;
__delay_ms(80);
PORTC = 0xD2;
__delay_ms(80);
PORTC = 0xD6;
__delay_ms(120);
PORTC = 0xD2;
__delay_ms(120);
PORTC = 0xD6;
__delay_ms(120);
PORTC = 0xD2;
__delay_ms(120);
PORTC= 0xD6;
__delay_ms(140);
PORTC = 0xD2;
__delay_ms(140);
PORTC = 0xD6;
__delay_ms(140);
PORTC = 0xD2;
__delay_ms(140);
PORTC = 0xD6;
__delay_ms(140);
PORTC = 0xD2;
__delay_ms(160);
PORTC = 0xD6;
__delay_ms(160);
PORTC = 0xD2;
__delay_ms(160);
PORTC = 0xD6;
__delay_ms(180);
PORTC = 0xD2;
__delay_ms(180);
PORTC = 0xD6;
__delay_ms(180);
PORTC = 0xD2;
__delay_ms(180);
PORTC= 0xD6;
__delay_ms(180);
PORTC = 0xD2;
__delay_ms(200);
PORTC= 0xD6;
__delay_ms(200);
PORTC= 0xD2;
__delay_ms(220);
for(n=0;n<=stepcnt;n++) //loop to maintain final speed after deceleration table implentation
PORTC = 0xD2;
__delay_ms(15);
PORTC = 0xD6;
__delay_ms(15);
void Run_Motor1_ccw(void) //function to run motor 1 counter clockwise
int n;
PORTC = 0x30; //initialise motor 1 and turn on led for motor 1
__delay_ms(10);
for(n=0;n<=stepcnt;n++) // loop to run motor one at contstan speed counter clockwise
PORTC = 0xB0;
__delay_ms(250);
PORTC = 0xB1;
__delay_ms(250);
int n;
PORTC = 0x50;
__delay_ms(10);
PORTC = 0xD0;
__delay_ms(250);
PORTC = 0xD4;
__delay_ms(250);
void Accel_Motor1_ccw(void)//FUNCTION FOR CCW ACCELERATION OF M1
int x;
PORTC= 0xB0; //delay tables to accelerate motor 1
__delay_ms(250);
PORTC = 0xB1;
__delay_ms(250);
PORTC = 0xB0;
__delay_ms(250);
PORTC = 0xB1;
__delay_ms(220);
PORTC = 0xB0;
__delay_ms(220);
PORTC = 0xB1;
__delay_ms(220);
PORTC = 0xB0;
__delay_ms(220);
PORTC = 0xB1;
__delay_ms(200);
PORTC = 0xB0;
__delay_ms(200);
PORTC = 0xB1;
__delay_ms(200);
PORTC = 0xB0;
__delay_ms(200);
PORTC = 0xB1;
__delay_ms(170);
PORTC = 0xB0;
__delay_ms(170);
PORTC = 0xB1;
__delay_ms(170);
PORTC = 0xB0;
__delay_ms(170);
PORTC = 0xB1;
__delay_ms(140);
PORTC = 0xB0;
__delay_ms(140);
PORTC = 0xB1;
__delay_ms(140);
PORTC = 0xB0;
__delay_ms(140);
PORTC = 0xB1;
__delay_ms(100);
PORTC= 0xB0;
__delay_ms(100);
PORTC= 0xB1;
__delay_ms(100);
PORTC= 0xB0;
__delay_ms(100);
PORTC = 0xB1;
__delay_ms(60);
PORTC =0xB0;
__delay_ms(60);
PORTC = 0xB1;
__delay_ms(60);
PORTC = 0xB0;
__delay_ms(60);
PORTC = 0xB1;
__delay_ms(30);
PORTC = 0xB0;
__delay_ms(30);
PORTC = 0xB1;
__delay_ms(30);
PORTC = 0xB0;
__delay_ms(30);
PORTC = 0xB0;
__delay_ms(15);
PORTC = 0xB1;
__delay_ms(15);
int a;
PORTC = 0xB0;
__delay_ms(15);
PORTC = 0xB1;
__delay_ms(15);
PORTC = 0xB0;
__delay_ms(25);
PORTC = 0xB1;
__delay_ms(25);
PORTC= 0xB0;
__delay_ms(25);
PORTC = 0xB1;
__delay_ms(25);
PORTC= 0xB0;
__delay_ms(60);
PORTC= 0xB1;
__delay_ms(60);
PORTC= 0xB0;
__delay_ms(60);
PORTC = 0xB1;
__delay_ms(60);
PORTC = 0xB0;
__delay_ms(80);
PORTC = 0xB1;
__delay_ms(80);
PORTC = 0xB0;
__delay_ms(80);
PORTC = 0xB1;
__delay_ms(80);
PORTC = 0xB0;
__delay_ms(120);
PORTC = 0xB1;
__delay_ms(120);
PORTC = 0xB0;
__delay_ms(120);
PORTC = 0xB1;
__delay_ms(120);
PORTC= 0xB0;
__delay_ms(140);
PORTC = 0xB1;
__delay_ms(140);
PORTC = 0xB0;
__delay_ms(140);
PORTC = 0xB1;
__delay_ms(140);
PORTC = 0xB0;
__delay_ms(140);
PORTC = 0xB1;
__delay_ms(160);
PORTC = 0xB0;
__delay_ms(160);
PORTC = 0xB1;
__delay_ms(160);
PORTC = 0xB0;
__delay_ms(180);
PORTC = 0xB1;
__delay_ms(180);
PORTC = 0xB0;
__delay_ms(180);
PORTC = 0xB1;
__delay_ms(180);
PORTC= 0xB0;
__delay_ms(180);
PORTC = 0xB1;
__delay_ms(200);
PORTC= 0xB0;
__delay_ms(200);
PORTC= 0xB1;
__delay_ms(220);
for(a=0;a<=stepcnt;a++)
PORTC = 0xB1;
__delay_ms(250);
PORTC = 0xB0;
__delay_ms(250);
int z;
PORTC = 0xD0;
__delay_ms(250);
PORTC = 0xD4;
__delay_ms(250);
PORTC = 0xD0;
__delay_ms(250);
PORTC = 0xD4;
__delay_ms(220);
PORTC = 0xD0;
__delay_ms(220);
PORTC = 0xD4;
__delay_ms(220);
PORTC = 0xD0;
__delay_ms(220);
PORTC = 0xD4;
__delay_ms(200);
PORTC = 0xD0;
__delay_ms(200);
PORTC = 0xD4;
__delay_ms(200);
PORTC = 0xD0;
__delay_ms(200);
PORTC = 0xD4;
__delay_ms(170);
PORTC = 0xD0;
__delay_ms(170);
PORTC = 0xD4;
__delay_ms(170);
PORTC = 0xD0;
__delay_ms(170);
PORTC = 0xD4;
__delay_ms(140);
PORTC = 0xD0;
__delay_ms(140);
PORTC = 0xD4;
__delay_ms(140);
PORTC = 0xD0;
__delay_ms(140);
PORTC = 0xD4;
__delay_ms(100);
PORTC= 0xD0;
__delay_ms(100);
PORTC= 0xD4;
__delay_ms(100);
PORTC= 0xD0;
__delay_ms(100);
PORTC = 0xD4;
__delay_ms(60);
PORTC =0xD0;
__delay_ms(60);
PORTC = 0xD4;
__delay_ms(60);
PORTC = 0xD0;
__delay_ms(60);
PORTC = 0xD4;
__delay_ms(30);
PORTC = 0xD0;
__delay_ms(30);
PORTC = 0xD4;
__delay_ms(30);
PORTC = 0xD0;
__delay_ms(30);
PORTC = 0xD4;
__delay_ms(30);
for(z=0;z<=stepcnt;z++)
PORTC = 0xD0;
__delay_ms(15);
PORTC = 0xD4;
__delay_ms(15);
/*void Deccel_Motor2_ccw(void)
// int n;
/* PORTC = 0xD0; //delay tables to decelerate motor 2 counter clockwise
__delay_ms(15);
PORTC = 0xD4;
__delay_ms(15);
PORTC = 0xD0;
__delay_ms(25);
PORTC = 0xD4;
__delay_ms(25);
PORTC= 0xD0;
__delay_ms(25);
PORTC = 0xD4;
__delay_ms(25);
PORTC= 0xD0;
__delay_ms(60);
PORTC= 0xD4;
__delay_ms(60);
PORTC= 0xD0;
__delay_ms(60);
PORTC = 0xD4;
__delay_ms(60);
PORTC = 0xD0;
__delay_ms(80);
PORTC = 0xD4;
__delay_ms(80);
PORTC = 0xD0;
__delay_ms(80);
PORTC = 0xD4;
__delay_ms(80);
PORTC = 0xD0;
__delay_ms(120);
PORTC = 0xD4;
__delay_ms(120);
PORTC = 0xD0;
__delay_ms(120);
PORTC = 0xD4;
__delay_ms(120);
PORTC= 0xD0;
__delay_ms(140);
PORTC = 0xD4;
__delay_ms(140);
PORTC = 0xD0;
__delay_ms(140);
PORTC = 0xD4;
__delay_ms(140);
PORTC = 0xD0;
__delay_ms(140);
PORTC = 0xD4;
__delay_ms(160);
PORTC = 0xD0;
__delay_ms(160);
PORTC = 0xD4;
__delay_ms(160);
PORTC = 0xD0;
__delay_ms(180);
PORTC = 0xD4;
__delay_ms(180);
PORTC = 0xD0;
__delay_ms(180);
PORTC = 0xD4;
__delay_ms(180);
PORTC= 0xD0;
__delay_ms(180);
PORTC = 0xD4;
__delay_ms(200);
PORTC= 0xD0;
__delay_ms(200);
PORTC= 0xD4;
__delay_ms(220);
PORTC = 0xD0;
__delay_ms(250);
PORTC = 0xD4;
__delay_ms(250);
/*void interrupt ISR(void)
if (INTEDG == 1 && INTF == 1) //IF INTERRUPT FLAG IS SET AND INTERRUPT IS AT RISING EDGE
Run_Motor1_cw(); //call motor 2 to start
INTEDG = ~INTEDG; //toggle intedg to allow for the two types of input from the transmitter
Run_Motor2_ccw(); //call motor 1 to start
INTF = 0; //CLEAR INTERRUPT FLAG BITl
