jasman
Newbie level 3
i have this problem sometimes when try to connect two PCs together: it happens that sometimes when i network two pcs using a cross cable and i try to access one from the other, i receive a message like "The path is not accessible contact your network administrator". I made sure i play by the rule anytime i do it, like taking ip address from the same network address, using the same subnetmask, using the same workgroup name, sharing files and folder, yet the same problem still persists. i will appreciate it if anyone can help tell me what could be the cause(s) of this problem.
