[SOLVED] Help with multiplexed display
madalin1990
Full Member level 2
I am trying to decribe a verilog module for a multiplexed display,but i just keep doing it wrong.Here is what i have tried.If someone could tell me where is my mistake i would be grateful.
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
module selector(
clk,
rst,
an_sel,
data0,
data1,
data2,
data3,
data4,
data_out
input clk,rst;
output reg [4:0] an_sel;
output reg [2:0] data_out;
input [7:0] data0,data1,data2,data3,data4;
reg q;
always @(posedge clk,posedge rst)
begin:COUNTER
if(rst == 1'b1)begin
    q <=3'b0;
    end  else
    if(q==3'b100)begin
    q<= 3'b0;
    end
     else begin
     q<=q+1;
     end
end
reg sel;
always @(q)
begin
if(q==3'b0)begin
an_sel <=5'b00001;// 5'b10000;
sel<=3'b0;
end else
if(q==3'b001)begin
an_sel <= 5'b00010;//5'b01000;
sel<=3'b001;
end else
 if(q==3'b010)begin
an_sel <=5'b00100;// 5'b00100;
sel<=3'b010;
end else
if(q==3'b011)begin
an_sel <=5'b01000;//5'b00010;
sel<=3'b011;
end else
begin
an_sel <=5'b10000;// 5'b00001;
sel<=3'b100;
end
end
always @(sel)
begin
case(sel)
  0:data_out = data0;
  1:data_out = data1;
  2:data_out = data2;
  3:data_out = data3;
  4:data_out = data4;
  default : data_out=~8'b00111111;
  endcase
  end
endmodule
First of all, what is the problem you are facing with this logic?.
Reactions: zhpyu
    zhpyu
madalin1990,
I never used Verilog language, in fact I've just ended up reading basic syntax for this post...
One thing I know... It is not normal to do that many operations between different sizes variables...
for example:
reg q; is one bit variable
you are assigning to it a 3 bit value and doing logic equality operations with 3 bits values...
reg q;
begin:COUNTER
    q <=3'b0;
You should declare it with 3bit size...
same thing appening with reg sel;
reg sel;
always @(q)
begin
if(q==3'b0)begin
sel<=3'b0;
reg sel should also be 3bit size
finally your data_out register is 3 bit wide, and you are assigning to it a 8bit wide variable:
  0:data_out = data0;
  1:data_out = data1;
  2:data_out = data2;
  3:data_out = data3;
  4:data_out = data4;
data_out should also be 8 bit wide by this logic... makes sense 7 segments plus a dot segment
once again I never used this language.. I can only guess what You mean with the code...
anyway I suggest:
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
module selector(
clk,
rst,
an_sel,
data0,
data1,
data2,
data3,
data4,
data_out
input clk,rst;
output reg [7:0] data_out;
reg [2:0] q;
begin:COUNTER
    q <=3'b0;
    end  else
    if(q==3'b100)begin
    q<= 3'b0;
    end
     else begin
     q<=q+1;
     end
end
reg [2:0] sel;
always @(q)
begin
if(q==3'b0)begin
sel<=3'b0;
end else
if(q==3'b001)begin
sel<=3'b001;
end else
 if(q==3'b010)begin
sel<=3'b010;
end else
if(q==3'b011)begin
sel<=3'b011;
end else
begin
sel<=3'b100;
end
end
always @(sel)
begin
case(sel)
  0:data_out = data0;
  1:data_out = data1;
  2:data_out = data2;
  3:data_out = data3;
  4:data_out = data4;
  endcase
  end
endmodule
It worked after making those changes.
Thank you!
