kevin360
Newbie level 3
lmc567
I'm hoping someone can shed some light on why this isn't working for me. At first I tried using two LMC567 chips that were both using the same value resistors and capacitors so they'd be at the same frequency (~2kHz). I then fed the output (pin 5) of the first LMC567 to the input (pin 3) of the second LMC567 but it didn't change the output at all. Since it wasn't working I thought that maybe the bandwidth was too narrow and the variance in the R & C components made the frequencies they operated at too different, so it wouldn't detect the tone. So the next test was to take one LMC567 and feed it's output (pin 5) to it's input (pin 3) - still no change at the output.
Right now the values I'm using are Rt=110k, Ct=3.3nF, C1=4.7uF, C2=4.7uF. If anyone wants me to draw up a circuit to see what it looks like I can do that, just let me know.
Thanks for any help you can give.
