dmorrill22
Newbie level 2
Sorry if this is the wrong forum or whatever, it seemed to be the right one.
Hopefully someone out there can help me.
I a somewhat of an amateur when it comes to making circuits for electronics. I know the basics, but this circuit is stumping me.
I need a circuit for an electric plow lift I am planning on making. It will have a DPDT switch for raise/lower. A motor hooked up to a sprocket that turns a drum by chain for the winch, and a door lock actuator to lock the winch so it won't release cable. This is mostly going to be made out of parts I have collected, which is why I am not buying a winch or something instead. It is much cheaper this way.
So this is what the circuit has to do:
When the switch is pressed for "raise", the motor needs to be turned on until the cable is all the way in. At the moment that the cable is all the way in, the motor needs to be shut off and the door lock actuator needs to be turned on to prevent the drum from lowering the plow.
When the switch is pressed for "lower", all that needs to happen is the door lock actuator's polarity gets reversed so it lowers, allowing the drum to freespool, lowering the plow.
Sorry if this is confusing to any of you.
I know that this circuit will need at least one relay and a timer, but I am stuck on how to wire it up. Can anyone make a schematic of this to help me? Thanks,
Doug
Doug
