I am very new and only have limited knowledge. Any help would be greatly appreciated. The circuit attached below is what I think I need. The circuit will control flow to two transformers that are attached to two neon lights. When the switch is pressed it should move power to load A and back to load B when released. Eventually I would like to replace the switch with a timer, which would allow each lamp to stay on about 3-5 min before switching. My question is, is this a good circuit design. It is my first attempt at a drawing so it is nothing more than a rough sketch. Thanks for any input.
I think it’s the best solution to use a timer, the question is: do you want to make one timer (by using a standard 555 circuit, capacitors and resistors) or considering buying off the shelf product?
---------- Post added at 19:37 ---------- Previous post was at 19:30 ----------
Circuit looks okay if you use ordinary switch to control the relay, for control using an external circuit (like based on 555 timer) it would need a diode across the relay coil to avoid a voltage spike going back into the control circuit.
If the lamp characteristics are similar enough, you could use 1 transformer, and use the relay to determine which lamp is connected across the transformer output.
Another option is to use a relay that only needs a jolt of power to switch position (but not continuously). Then you'd use a pulse of current to switch outputs, but don't need to power the relay continuously in 1 position.
I like the idea of off the shelf... but I also like to build. Do you think I will be able to find a relay that the coil would also
work on 120v so that I may only have one circuit. Also, do they have off the shelf times that will swing off and on every
3 to 5 min. well that is reasonable. This is just a fun do at home project.... Thank you for your reply and help
ps any 555 timer circuit diagram that would do what I need would be greatly appreciated.
As for the 555 circuit we need using some separate 9-12V power supply, the relay coil may also be rated for 12V. See foe example a timer diagram attached.
Yes, no special resistors, usually the 1/4W will do the trick.
By the way, have you already decided for the exact timings? Based on the timings we can calculate capacitor/variable resistors values.
I am thinking maybe 5 min on then 5 min off... I don't want to be too harsh on the transformers.
I am thinking too many power cycles may not be a good thing. I don't think I would have the circuit on more
than a couple of hours at a time..
For a long period of time you need to increase the variable resistor values up to 250k-470k and the capacitor value up to 1000uF-2200uF. But sometimes there’s a problem with long times and the leakage currents of the timing capacitor, PCB quality and the type of 555 used for. It is usually best for longer times to use the CMOS version of the 555 (TLC555CP). https://www.ti.com/lit/ds/symlink/tlc555.pdf
Maybe it’s better to run a counter (e.g. CD4060).
Circuit looks also very simple.
