Help with 8051 Code!!!
hsuri
Newbie level 5
I am new to Microcontrollers..need urgent help with the code..
Follwing is the code to display a single message on the sound of a clap using 8051
#include<reg51.h>
#define port P1
#define dataport P2  //Data port for LCD
#define sec 1000
//CONTROL PINS
sbit rs = port^0;
sbit rw = port^1;
sbit e = port^2;
sbit sensor_input=P0^0;
void delay(unsigned int msec) //Time delay function
int i,j ;
for(i=0;i<msec;i++)
 for(j=0;j<1275;j++);
void lcd_cmd(unsigned char item) //Function to send command to LCD
dataport = item;
rs= 0;
rw=0;
e=1;
delay(1);
e=0;
return;
void lcd_data(unsigned char item) // Function to send data to LCD
dataport = item;
rs= 1;
rw=0;
e=1;
delay(1);
e=0;
return;
void lcd_data_string(unsigned char *str)  //Function to send string to LCD
int i=0;
while(str[i]!='\0')
 lcd_data(str[i]);
 i++;
 delay(10);
return;
void main()
unsigned char str1[] ="HELLO";
unsigned char str2[] =" WORLD";
sensor_input=1;
sensor_input=0;
lcd_cmd(0x38);
lcd_cmd(0x0e);
lcd_cmd(0x01);
while(1)
 if(sensor_input==1)
  lcd_cmd(0x82);
  lcd_data_string(str1);
  lcd_cmd(0xc6);
  lcd_data_string(str2);
  delay(sec);
  lcd_cmd(0x01);
  delay(100);
---------- Post added at 12:03 ---------- Previous post was at 12:02 ----------
Urgent help required...plzz:-?
keil is the good compiler
---------- Post added at 12:53 ---------- Previous post was at 12:47 ----------
yes code is correct
no errors and no warnings i have checked
what is your problem?
no display in lcd?
try to give more delay while command 0x38
some lcd's need to write the 0x38 three times first give 15ms delay and 5ms delay and 1ms delay
still error
You can also use a simulator, ( Proteus, for example ) to check if program behave like expected.
@hsuri : thats the same code given at EngineersGarage website.. i have made this project and it is working fine. Use Keil for compiling the code.
