Help! Who knows the pseudo-random binary sequence?
FPGAs
Member level 1
Member level 1
Shanghai, China
pseudo random binary sequence lfsr
would you please give me some datasheet or VHDL code?
thanks a lot!
echo47
Advanced Member level 6
USA
generate binary random sequences in c
A Linear Feedback Shift Register (LFSR) is an easy way to generate a pseudo-random bit stream in hardware by using a shift register and XNOR gate. Here are a couple of Xilinx app notes, and HDL examples:
FPGAs
Member level 1
Member level 1
Shanghai, China
pseudorandom binary sequence xilinx
Thank you very much.
Is there any other complex pseudo-random binary sequence?
Buriedcode
Full Member level 6
Full Member level 6
London
how to generate pseudo-random binary sequences
echo47 hit the nail on the head.
A single LFSR of length say, 18 will generate a very long pseudo random string of 1's and 0's, but you can always 'modulate' this. Simply by using more than one LFSR.
For example, if you create two LFSR's of the same length, but with different polynomials (feedback taps), and then have a third LFSR of a shorter length who's output determines which of the other two is used in the sequence. So, our two 'big' LFSR's are A and B. The smaller one C, when it outputs a '1', the output from A is used. When C outputs a '0' the output from B is used.
Obviously, if A,B and C are all the same legth, the length of the sequence is the same as the legth of A's sequence. But...make C shorter, by 2 (so a length of 16) and the random sequence will be huge.
I'm sure there are some *.pdf's on the web for CDMA, 3G phones. They use silly pseudo-random sequences that are repeated every few days. These use multiple LFSR's.
BuriedCode.
Ps. I'm no expert, but I have build random sequence generators for testing BER of radio channels. Some of which are a few billion bits long.
