Dears,
I made design of UWB antenna with finite substrate and microstrip feed line , i want to know if there is any mistake in drawing (specially for finite substrate and port feed on edge) and the result of simulation takes much time , i attached file that have Hexagonal Antenna for UWB applications.
UWB antenna design Factors:-
ε r = 2.2, h = 1.57 mm
The dimension of the ground plane is chosen to be (30 x 12) mm2 in this study.
The original design has a hexagonal radiator with side length 8 mm
The feed width (wf) is set to be 3 mm and the feed length (fl) is set to be 13 mm.
Thanks.
