I recently had a project handed to me at work to improve the range of our 2.4 GHz radio. Now I'm an experienced engineer but not an RF specialist, and we don't have any RF people. I've suggested we get some consulting help but was shot down pretty quickly. Also we don't buy enough parts to get any love from the mfg. I am allowed to rent gear, and I have access to some simulation tools for both RF and spice (I'm better with spice than the RF tools). The first thing I wanted to understand is the matching and balun network that take this differential transceiver and put it into a single ended 50 Ohm antenna. I spent the day re-learning smith charts, learning about single ended matching, trying matching exercises, reading app notes from various suppliers, and of course reading the suggested threads before posting here.
Here's my circuit, and the data sheet says the suggested load impedance should be 12+13j
Now I spiced the section marked balun and I found the top and bottom had a resonance near my frequency of interest, with a phase shift. So I think the purpose of that is to combine the positive and negative into a single ended signal. I struggled to understand what effect this portion had on the impedance.
I think C9 and C8 are just DC blocking caps.
I don't know what C10 does.
I think L5, C11, and C12 are some kind of choke? Not sure why you need DC here.
C4 I think is just another DC blocking cap?
C2,C3,L1,L2 I think are supposed to be the matching network for the antenna although it did not seem to match from 12-13j to 50Ohm. I've considered the idea that this design was tuned and takes into account all the parasitics of the layout but I'm not sure if that's what's throwing me off.
L7,L8,L9,L10,C15 I think are some sort of balanced filter for the RX? I haven't looked into this part yet.
The thing I really can't understand is the impedance of this circuit. Based on the statement that the transmitter wants a load of 12+13j, and the antenna is supposed to be 50Ohms, i thought I could work my way back adding each component to a smith chart (with smith chart tool) and in the end I'd find myself at 12-13J the conjugate of the load impedance they specify. I even tried doubling the values in the differential section to treat them as single ended. No matter what I tried I failed pretty miserably here, and it's quite literally keeping me up and night right now. If anyone would be kind enough to try to help me understand this circuit and put me on the path to higher learning I would really appreciate it. I'm trying to teach myself some things but I hit a wall here.
I was thinking about renting a VNA and just measuring everything but that won't really teach me what's happening. I could try simulating too but still I don't know that would lead to understanding.
