Help to get Answer in VHDL code for use Floting point and RAM
Adnan86
Full Member level 2
I want to design a system with VIVDAO 18.3 version(Virtex-7 and xc7vx485tffg1157-1) by using VHDL code and also used FP-IP (latency = 2) and RAM IP.
I saved numers in coe file: address 0 to end have these value= > c190 0000, 4118 0000,411c 0000,4000 0000, c000 0000, 4000 0000 , c000 0000 , ....
As I used floating point IP. fused multiply-add => Y = (AxB) + C; I want the program to read A,B,C in RAM and Save Y in RAM. my code works good but my answer happened with one loop delayed. instead, my answer saved in address = 03 , the answer (Y) saved in address = 6. I know maybe because of delay and latency, this is happend but how I can change code to fix this problem.
the code is:
-- Company:
-- Engineer:
-- Create Date: 12/29/2018 09:31:20 PM
-- Design Name: Adnan
-- Module Name: SP_RAM - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity SP_RAM is
  Port (
        ----- Bit Control & Addess ------
        clk         :   IN      STD_LOGIC;
       -- OP          :   IN      STD_LOGIC;
        rstN        :   IN      STD_LOGIC;
       -- addr          :   IN      STD_LOGIC_VECTOR(4 DOWNTO 0);
       -- addrB          :   IN      STD_LOGIC_VECTOR(4 DOWNTO 0);
       -- addrC          :   IN      STD_LOGIC_VECTOR(4 DOWNTO 0);
       -- addrOUT        :   IN      STD_LOGIC_VECTOR(4 DOWNTO 0);
        ------ Inputs data ----------------
        ------ Output datas --------------
        data_out    :   OUT     STD_LOGIC_VECTOR(31 DOWNTO 0);
     --   addr_out    :   OUT     STD_LOGIC_VECTOR(4 DOWNTO 0);
        Vout        :   OUT     STD_LOGIC
end SP_RAM;
architecture Behavioral of SP_RAM is
---------- RAM 32 bits ----------
COMPONENT dist_mem_gen_0
  PORT (
    a : IN STD_LOGIC_VECTOR(4 DOWNTO 0);
    d : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
    clk : IN STD_LOGIC;
    we : IN STD_LOGIC;
    spo : OUT STD_LOGIC_VECTOR(31 DOWNTO 0)
END COMPONENT;
----------- Single Precision ---------
COMPONENT floating_point_0
  PORT (
    aclk : IN STD_LOGIC;
    aclken : IN STD_LOGIC;
    aresetn : IN STD_LOGIC;
    s_axis_a_tvalid : IN STD_LOGIC;
    s_axis_a_tdata : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
    s_axis_b_tvalid : IN STD_LOGIC;
    s_axis_b_tdata : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
    s_axis_c_tvalid : IN STD_LOGIC;
    s_axis_c_tdata : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
    m_axis_result_tvalid : OUT STD_LOGIC;
    m_axis_result_tdata : OUT STD_LOGIC_VECTOR(31 DOWNTO 0)
END COMPONENT;
--------------- Signals---------------
SIGNAL      A:       STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL      B:       STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL      C:       STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL      Y:       STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL  d_in:       STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL d_out:       STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL address:     STD_LOGIC_VECTOR(4 DOWNTO 0);
SIGNAL addr   :     STD_LOGIC_VECTOR(4 DOWNTO 0):= "00000";
SIGNAL      clkEN:  STD_LOGIC;
SIGNAL      VA:  STD_LOGIC;
SIGNAL      VB:  STD_LOGIC;
SIGNAL      VC:  STD_LOGIC;
SIGNAL      wrEN:  STD_LOGIC;
SIGNAL   count: integer := 0 ;
--------------- read & write and nothing state ----
-- s0 : nothing -- s1 : read -- s2 : write
TYPE state_type is (s0, s1, s2);
---- Siganl
SIGNAL state : state_type;
begin
--------------------------- Port Map RAM ----------------------------------
-------- Input & Output -------------
ram1 : dist_mem_gen_0
  PORT MAP (
    a => address,
    d => d_in,
    clk => clk,
    we => wrEN,
    spo => d_out
--------- Port Map SP -------------
sp1 : floating_point_0
  PORT MAP (
    aclk => clk,
    aclken => clkEN,
    aresetn => rstN,
    s_axis_a_tvalid => VA,
    s_axis_a_tdata => A,
    s_axis_b_tvalid => VB,
    s_axis_b_tdata => B,
    s_axis_c_tvalid => VC,
    s_axis_c_tdata => C,
    m_axis_result_tvalid => Vout,
    m_axis_result_tdata => Y
--data_out <= Y;
------------ Main Process ---------
    PROCESS (clk, rstN)
	--VARIABLE   count: integer := 0 ;
	BEGIN
		IF rstN = '0' THEN
			--A <= (OTHERS => '0');
			--B <= (OTHERS => '0');
			--C <= (OTHERS => '0');
			--Y <= (OTHERS => '0');
			--d_in <= (OTHERS => '0');
			--d_out <= (OTHERS => '0');
			address <= (OTHERS => '0');
			addr <= (OTHERS => '0');
			wrEN <= '0';
		   clkEN <= '0';
		   VA <= '0';
		   VB <= '0';
		   VC <= '0';
		state <= s0; -- Do nothing
		ELSIF clk'event AND clk = '1' THEN
		      CASE state IS
		          WHEN    s0 =>
		              IF count /= 0 THEN
		              count <= 0;
		              clkEN <= '0';
		              address <= addr;
		              wrEN <= '0';
		              state <= s0;
		              VA <= '0';
		              VB <= '0';
		              VC <= '0';
		              ELSE
		              state <= s1;
		              clkEN <= '0';
		              address <= addr;
		              wrEN <= '0';
		              VA <= '0';
		              VB <= '0';
		              VC <= '0';
		              count <= 0;
		              END IF;
		             -- IF op = '0' THEN
		             -- count <= 0;
		             -- state <= s0;
		             -- clkEN <= '0';
		             -- wrEN <= '0';
		             -- VA <= '0';
		             -- VB <= '0';
		             -- VC <= '0';
		             -- address <= addr;
		            --  ELSE
		            --  state <= s1;
		            --  count <= 0;
		            --  wrEN <= '0';
		            --  clkEN <= '0';
		            --  address <= addr;
		            --  END IF;
		          WHEN    s1 =>   -- read A
		              IF count = 0    THEN
		              A <= d_out;
		              VA <= '1';
		              count <= count +1;
		              address <= STD_LOGIC_VECTOR(UNSIGNED(addr) + 1);
		             -- address <= address + 1;
		              wrEN <= '0';
		              clkEN <= '0';
		              END IF;
		              IF count = 1    THEN    -- Read B
		              B <= d_out;
		              VB <= '1';
		              count <= count +1;
		              address <= STD_LOGIC_VECTOR(UNSIGNED(addr) + 2);
		              wrEN <= '0';
		              clkEN <= '0';
		              END IF;
		              IF count = 2    THEN    -- Read C
		              C <= d_out;
		              VC <= '1';
		              count <= count +1;
		              address <= STD_LOGIC_VECTOR(UNSIGNED(addr) + 3);
		              wrEN <= '0';
		              state <= s2;
		              clkEN <= '1';
		              END IF;
		              --IF count = 3 THEN  -- Stay in Read Mode 1 clk more
		              --state <= s2;
		              --address <= STD_LOGIC_VECTOR(UNSIGNED(addr) + 3);
		              --END IF;
		          WHEN    s2 =>   -- write
		              IF count = 3    THEN
		              d_in <= Y;
		              count <= count +1;
		              addr <= STD_LOGIC_VECTOR(UNSIGNED(address) );--+1
		              wrEN <= '1';
		              clkEN <= '1';
		              --state <= s0;
		              END IF;
		              IF count = 4 THEN
		              --IF d_in /= d_out THEN
		              --state <= s2;
		              --ELSE
		              --count <= count +8;
		              state <= s0;
		              --wrEN <= '0';
		              --clkEN <= '0';
		              --VA <= '0';
		              --VB <= '0';
		              --VC <= '0';
		              --data_out <= d_out;
		              --END IF;
		              END IF;
		       END CASE;
		    END IF;
	END PROCESS;
--addr_out <= address;
data_out <= d_out;
end Behavioral;
and the wave:
I Will aprecite to help me.
You should delay the write to the RAM until the floating point IP would have the valid value at the output.
Figure out why you have X'es in the simulation.
thank you for answering.
about X', i already have this problem in address as i find out i connect 1 and 0 in some connetion. but about delay the write to the ram until FP IP would have the valid, i tried it but i couldnt solve the problem.
i wll appreciate to give me some clue to find out.
