help to design for gsm 900 & 1800 range with gain of
Ghost Tweaker
Member level 5
PIFA antenna
Hi everyone,
does someone have an article about how to compute a PIFA antenna dimensions for a given frequency and/or a model for PIFA antenna. I don't really understand the principle of this antenna...
Thanx in advance
Re: PIFA antenna
You can find some discussion of PIFA antennae (no design equations though) in chapter 3 of the ebook;
Compact and Broadband Microstrip Antennas
by KIN-LU WONG
You can dowload the ebook from MCU fileman under the path,
Home/eBookOld/RF design/Compact Aand Broadband Microstrip Antennas.zip
link is;
Re: PIFA antenna
Thanks a lot for the link, this is a huge resource. I will now have a look at the ebook.
Re: PIFA antenna
Ghost Tweaker said:
Hi everyone,
does someone have an article about how to compute a PIFA antenna dimensions for a givean frequency and/or a model for PIFA antenna. I don't really understand the principle of this antenna...
Thanx in advance
I think the simplest way to make pifa antenna is to make normal rectangular patch with for instance coax feed working on required frequency. Than, cut the patch in the half of the E-plane and put on the cut line shorting wall to the ground and throw away cut half of the patch. Of course not that half with feeding. :)
Check the book which ajar2dtn propsed you. :)
Greets,
Redi.
Re: PIFA antenna
Dear ajar2dtn,
things become more clear with the help of the ebook. Do u have other links for ebooks?
GhostTweaker
Re: PIFA antenna
Hello MW Antenna People,
hi need and antenna working from 6 to 18 GHz in dual linear polarization.
Do u have any ideas?
Merry Christmas
Lupin
Re: PIFA antenna
Dear Redi,
as I understand your explanation is more a lambda/4 p_atch antenna. For me PIFA is feed line with one arm going to ground and the other arm left open. It's strange, everywhere I look, I never find a clear explanation or paper about this antenna. Anyway, thanks for your help. :D
Ghost Tweaker
Re: PIFA antenna
Ghost Tweaker said:
Dear Redi,
Ghost Tweaker
In the book mentioned here Compact And Broadband Microstrip Antennas by Wong, PIFA is refered also as probe-fed shorted patch. And when you take lambda/4 patch and you short it to the ground, because it is necessary and you will feed this patch by probe you will get PIFA. Just look at such structure from side view (substrate cut) and you will see the inverted F letter, where one arm of F letter is probe feed, second shorting wall and the rest of the letter is patch. :)
Greets,
Redi.
Re: PIFA antenna
Thanx a lot Redi, finally something clear. So the PIFA is the p atch version. How do u call the version where the F is in the PCB plane?
Ghost...
Re: PIFA antenna
u could read ieee paper the keyword:pifa & antenna to find out its
or goes to google to find this paper:
Antenna Design for Wearable Application
Re: PIFA antenna
Ghost...
When F is on PCB it is called simply IFA. Check this topic on Elektroda, you will find there a lot of information:
Greets,
Redi.
Re: PIFA antenna
hi all
i cant seem to dl from mcu
a window keeps opening with
FTP Error : 550 /eBookOld/RF design/: Permission denied
Current state : 4
however i am logged in
