[SOLVED] Help:SD card Simulation with ISIS proteus
Momos1989
Junior Member level 2
hello eveyone,
I'm trying to make a simulation of SD card with ISIS Proteus , the code for the Microcontrolleur is in C langage! but I don't know why i don't get something in the virtual terminal !!! help mee pleaaazz!!!
here is the code:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
// This function sends carriage-return and line-feed to USART
sfr sbit Mmc_Chip_Select at RC2_bit;
sfr sbit Mmc_Chip_Select_Direction at TRISC2_bit;
void Newline()
Soft_Uart_Write(0x0D); // Send carriage-return
Soft_Uart_Write(0x0A); // Send line-feed
// This function sends a space character to USART
void Space()
Soft_Uart_Write(0x20);
// This function sends a text to serial port
void Text_To_Usart(unsigned char *m)
unsigned char i;
i = 0;
while(m[i]!= 0)
{ // Send TEXT to serial port
Soft_Uart_Write(m[i]);
i++;
// This function sends string to serial port. The string length is passed as an argument
void Str_To_Usart(unsigned char *m,unsigned char l)
unsigned char i;
unsigned char txt[4];
i=0;
for(i=0; i<l; i++)
ByteToStr(m[i],txt);
Text_To_Usart(txt);
Space();
// Start of MAIN program
void main()
unsigned char error,CID[16];
unsigned char msg[] = "S";
// Configure the serial port
Soft_Uart_Init(PORTC,7,6,2400,0); // TX=RC6
// Initialise the SD card
SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV16, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
// Initialise the SD bus
while(Mmc_Init());
// Start of MAIN loop. Read the SD card CID register and send the data
// to serial port every 10 seconds
for(;;)  // Endless loop
Text_To_Usart(msg); // Send TEXT
Newline(); // Send newline
error = Mmc_Read_Cid(CID); // Read CID register into CID
// Send the data to RS232 port
Str_To_Usart(CID,16); // Send CID contents to UART
Delay_Ms(10000); // Wait 10 seconds
Newline();
Newline();
