Help required with DSP c6713
Communications_Engineer
Advanced Member level 3
Sindh, Pakistan
Can you help me with the following problem with TI DSP c6713
After installing CCS 3.3 and using it with Matlab 7.8, I was able to create a project for taking input from ADC and forward the output to DAC, however now I'm getting this error
"RTDX target application does not match emulation protocol! Loaded program was created with an rtdx library which does not match the target reference"
Any suggestions on how to remove this error?
