Help required: How to generate rf sweep
ashwanthh
Junior Member level 2
Hi all,
In my project, I need to generate sweep signals for the frequency range for GSM bands ie. 890-960Mhz and 1710-1860Mhz.
1. How to generate sweep signals for the above frequency range ?
2. Can it be generated for the above frequency or should i generate sweep signal for 2ghz and select the above two frequencies while sending?
3. What components should be used ?
Please help me with some ideas
I think you should win an award for the biggest number of cross-posts ever.
Try reading a book on how PLL work, it will answer ALL the questions you posted.
Brian.
