Help required for logarithmic equation
Delta11
Junior Member level 3
Need help solving a logarithmic equation:
(1/x) . exp(-x^2) = 10^-6.
Thanks.
If you just need a numerical result, you can use the free math tool Scilab. Code you have to write is:
deff('[y]=funct(x)','y=exp(-x^2)/x-1e-6');
[xres]=fsolve(1,funct)
from which you will obtain x=3.5426862
    Delta11
You may solve it by iteratives methods.
(1/x) . exp(-x^2) = 10^-6 --> x_n = SQRT(LN(10^6/x_n_1))
Starting with x = 1 converge in few steps to 3.542686172...
    Delta11
Thanx for the help guys. Is there any other approach to solving this problem other than iterative method? Numerical iteration obviously fits but i am looking for a more conventional solution. It is a second order logarithmic equation after all!!!
It cannot be expressed by elementary functions.
You need special functions like the Lambert W-function (see Google).
If exp(-x^2)/x = a then x = sqrt( W(2/a^2) / 2 )
with W() the Lambert W-function
But... to obtain W() you need numerical methods or need software like Mathematica with the ProductLog[z] function...
use first few terms(depending on the accuracy) of the taylor's series of the exponential and divide by x. Now it's just solving a polynomial.
