Krishna Patil
Member level 1
- Joined
- May 8, 2011
- Messages
- 38
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Shimoga, Karnataka, India
- Activity points
- 1,582
Hello Everyone ,
I'm using RF 433Mhz modules like this one https://www.sunrom.com/143 . What will be bandwidth I'll be getting ?and what is the data rate ? In this datasheet https://www.robokits.co.in/datasheets/TXC1.pdf it is mentioned that 1kbps . How it is calculated ?
Does the data rate vary over distance for these modules like it happens in a Wifi Connection ? If it'll be varying how can I measure the data rate vs distance ?
Thank you,
Thank you,
