Help reg problem concered with combining vectors
Sharath1160
Newbie level 6
India
Dear all,
I have a vector of 1 X 70 for a spectrogram chunk containing some values. In this way, I have obtained a vector for other 120 chunks of size 1 X 70.
"If the vectors are combined, the size will be 120 X 70.
I need to combine all the 120 chunks as a single vector 1 X 70 to get the total. In this way I mean I need to add up all the values in the 70 columns to get the total which is of 1 X 70 "
I am confused on how to proceed. Kindle please suggest me on how to implement this.
Thanks and regards,
Sharath
If you have the data in a notepad, you can use either excel or matlab to do this.
I m using matlab only... I have 120 vectors corresponding to 120 spectrograms of size 1 X 70. Instead of taking all the vectors and copying it in notepad and then putting those in matlab and then computing is tedious na.. I want an alternative solution if possible. Since I have to compute it for 2880 spectrograms.. this looks to me as a tedious way..
