spiralup
Newbie level 2
I am trying to design an active band-pass filter with center frequency of 6.8MHz, bandwidth of 17kHz, and a gain of 14.
I used these values (14= (Rf/R1) +1)to select the resistors for the gain. I chose Rf to be 1300 and R1 to be 100.
Since BW = R/L, I chose R to be 170 and L to be 0.01. C was found to be 2.16E-12 (this is a bit suspicious to me, but it is what I have repeatedly calculated from center frequency = (R/2L) + (sqrt(R^2C^2+4LC)/2LC)).
I used a VAC source. The AC analysis from 10k to 20M yielded this linear plot:
and this decade plot:
For the linear plot, shouldn't taking 20*log[Vout/Vsource] yield the bode plot?
Both are giving an odd spike in the Vout around 1 MHz. It needs to be 6.8 MHz though. Changing the value of C did move the spike closer to 6.8MHz, but 2.16E-12 was my calculated value. I am not sure what to try next.
