Help Please: Pulse-time Modulation
yousif
Member level 1
Member level 1
pulse time modulation
Using a sawtooth signal to generate pulse width modulated signal
where we compare the sawtooth with the input analog signal
if the sawtooth > signal then comparator output = 1 state
if < then comparator output = 0 state
So the comparator output pulse duration depends on the signal sample level
Question:
What the minimum sawtooth siganl peak amplitude to do that job?
It is equal to maximum of input analog (feedback)voltage.
