Hi..
i have project ( fm radio sc1088)for simulation ...and i don't have this component in multisim so i wanna 2 make it with footproint(sop-16) according 2 data sheet but the problem in model maker i don't know how to make it the simulation part?
hope that u can help me ...
thanks
It is a very poorly performing radio circuit. An FM "radio" with it is only $1.00 at the Dollar Store. I got one free by subscribing to a newspaper. It barely picks up local FM stations, is overloaded by some and sounds horrible. Its reception of strong local stations fades all the time.
thanks Audioguru
but u still didn't help me ....i want 2 make the radio chip sc1088 on multisim ...the problem is the code ...i made the footprint (the layout :its shape and pins exactly as the real one )...but its still stone without the model maker (mathematic or code part )
so that i can't simulate it ...
thanks again
You don't know any of the details about the internal parts of the cheap receiver IC so you will not be able to make an accurate model for your simulator.
It is a lousy circuit. Why bother simulating it?
Just make it to see (hear?) how lousy it is. Or buy a radio that is already made with it.
thanks for ur reply ...
i made the layout (exactly the same as the real one according to datasheet which its sop-16 footprint)
the problem is the simulation part ,,,i know its very difficult
help me with any fm receiver chip or Ic (like sc1088 ),,,
thanks again ,,,sorry 2 bother you
It is too much trouble to make a sim model of such a complicated IC without knowing any of its internal details. Your model won't match it and the model would probably not work anyway
Multisim might not know what is an RF mixer or what is a varicap diode.
Philips invented it and don't make it anymore because it is too old.
Simulate a more modern and better performing circuit.
The TDA7000 has not been made for many years and its performance was horrible. Local stations overload it.
Its circuit is completely different from all other super-het radios.
From one page about TDA 7000:
My recommendation is that you gear down the tuning control with a reduction drive, or use a pot with varicap diode. Leave the squelch enabled, or at least have a switch if you want to disable it. And don't expect it to perform as a Super DX receiver. As with all kinds of receiver, give it a decent aerial!
I highly recommend this IC for where non technical users are involved and where sound quality is important. For what it is, and the simplicity of use, it makes an excellent FM receiver.
