help Pic16F628a connection
There is no specification for that particular device but I would guess it runs off 3.3V maximum supply. If you can run the PIC from 3.3V there should be no problem with a direct connection. If the PIC is running from 5V, connect the output of the bluetooth module directly to the input of the PIC and connect the output of the PIC through a potential divider to the module. You should be able to make the divider from a 1K resistor in series with the signal and 1.5K to ground across the input to the module. That will drop the PIC 5V levels down to about 3.3V.
Brian.
Reactions: brian25
    brian25
