Help on Simulation on HSPICE
awan
Los Angeles
Hi;
I am new to HSPICE and trying to simulate simple ID vs. VGS characteristics of a MOSFET. Can someone please help me to verify the following is the netlist:
I am not getting the variation of current against the DC voltage.
Question 1
VDD 10 0 DC 2.5
M1 2 1 0 0 CMOSN w=10u l=.25u
R 10 2 1000
VIN 1 0 DC 10
.DC VIN 0 10 0.1
.PLOT I(2) V(1,0)
Also, attached is the Output file for the simulation.
Thanks
I don't think it is going to work,
You should either have a .tran or a .ac command in your code depending on your simulation.
Also, I always prefer to define the voltage source as follows:
Vdd dd 0 1
I do not think putting the DC makes any difference. If it does, please tell me
I think it works,if only add some options such as ".option node list post........"
In your case so far as I know, no pic will be seen.
Yes, add a statement like .options post=1
The problem is that the current is being measured as I(2). Rather it should be meaured through the device like I(m1).
If you want to get I-V curves of a MOSFET, you can compose a netlist as bellow:
$title line
MI1 D G GND GND NMOS w=10u l=0.25u
VDS D GND
VGS G GND
.options post
.dc VDS 0 2.5 0.5 VGS 0 2.5 0.5
.print dc I(MI1)
.end
