does anybody use hsim to simulate jitter of pll?
with hsim, i can get peak to peak jitter and RMS jitter using .measure.
some said i can't get jitter with just transient simulation.
so i wonder where does this jitter come from? is it from flicker noise of the mosfets? does these peak to peak jitter and RMS jitter make sence?
In your transient simulation, no thermal noise or flicker noise is included in your simulation. Some famous company can do transient thermal noise analysis using its own tools
When you simulate pll, the jitter may occur these conditions :
1.VCO Gain too big(voltage of VCO can't ideal stable, it has a little ripple)
2.PFD dead zone
3.If you charge pump type pll, & c of filter is not big enouge, leage current
will effect voltage of VCO .
