lionelgreenstreet
Junior Member level 3
Help on output stage
I have simulated a class A push-pull amplifier, but i don't understand
what i've obtained...
In a class A push pull the maximum current in load is Imax=2*Iquies;
so if load is R//C :
1)Voutmax=R*Imax
2)slewrate=Imax/C
Is it right?
If i use as load only R, the first condition is met; but if i consider
only C (without parallel resistor), slew rate is very high and i don't
understand why.....can you help me?
Thanks in advance
1)Voutmax=R*Imax
2)slewrate=Imax/C
Is it right?
Thanks in advance
