I have a waveform from analog simulator, both time and voltage values are stored in a text file. The signal represented is a digital "1,0" stream.
What wanted in matlab processing is the digital information carried in. How to convert them into a stream of one zero digital symbols, without so much useless overhead?
This represents a digital waveform in analog way. It is a NRZ coded bit stream with constant bit rate, i.e. each bit is equally spaced in time domain, however, not equally spaced in index. Time step is not constant.
What I want to do is to extract digital one/zero information from that and generate a 1010 stream.
