Help on driving CS8190 Driver
Ehsoon
Newbie level 2
Newbie level 2
Iran
hi dears.
I'm a bit new in Electronic, and now want to make a tachometer. I designed protection and supply circuit according to CS8190 datasheet and another tachometer's PCB. I've produced the 8.9v DC voltage for pin8 of CS8190 and a square wave to pin3. but now I can't see any thing in pin2. Can any one guess where the problem can be?
Reactions: Ehsoon
    Ehsoon
yes Frank,I am. And my last problem has been solved :grin: , now I'm trying to calibrate the tacho according the given data. I calculated C4 and Rt(mentioned in cherry datasheet) for 5KHz Max freq. and 278deg, 0.47uF and 17.37Kohm(using a 20K potentiometer), but i think they're not properly calculated, because the needle didn't work right :?:
