John_Correa
Junior Member level 1
I am an undergraduate and I want to work on sensors. I wanted to build a distance measuring sensor using IR LED and IR photodiode. However I have not experienced much success as the output voltage is not at all consistent. Please suggest a circuit which can do the same using the above components with good reliability and accuracy.
