[HELP] NV-SIM Problem?
billjoy
Member level 1
Member level 1
setenv in verilog makefile
Q1:
In NC
if ncvhdl
ncverilog
is ok
but
ncelab with error **broken link removed**
Here is my run procesure
ncvhdl -work work ./fa.vhd ==> OK
ncvlog -work work ./adder4.v ==> OK
ncvhdl -work work ./testfixture.vhd ==> OK
ncelab -work work work.cfg_testadd4:configuration ==> not OK
--> message
ncelab:*E,MULVHD:possible bindings for instance of entity 'fa' in
`work.add4:module' are :
VITAL_MEMORY.FA :A
WORk.FA:A
ncelab : *E,CUVMUR:instance for module/UDP 'fa' in unsolved
in 'work.add4:module'.
what does this mean??
what elab is error??
Q2. In this case , I want to use ncsim generate *.fsdb
Is any master guy can tell me how to do this?
nand_gates
Advanced Member level 3
verdi command
It works fine for me I am using NC-sim ver 5.3-s001..
Using Novas Debug Systems with NC-Sim
Linking
We will use Debussy 5.3, LDV 5.0 and SOLARIS2 32bit OS in this example. Other platforms will have similar settings, except for the HP OS, the environment variable is SHLIB_PATH, instead of LD_LIBRARY_PATH. For detailed information please consult Novas Software's Installation documentation (<Novas_install>/doc/installation.pdf).
Platforms Supported:
* HP10 <=> HPPA <=> HP11_32bit
* HP11<=>HP11_64bit
* LINUX
* WINNT (libraries come up only when installed on windows)
* SOL2<=>SOLARIS2<=>SOL7_32bit
Verilog
Dynamic linking
To link the provided compiled library:
setenv LD_LIBRARY_PATH <Novas_install>/share/PLI/nc_xl/SOLARIS2/nc_shared
If you need to generate your own compiled library, the required files are pli.a and veriuser.c
They are located at <Novas_install>/share/PLI/nc_xl/SOLARIS2
Bootstrap Dynamic Linking
setenv LD_LIBRARY_PATH <Novas_install>/share/PLI/nc_xl/SOLARIS2/nc_loadpli1
ncverilog -f run.f +debug +loadpli1=debpli:debpli_boot
Static Linking
Copy and edit Makefile.nc from <Cadence_install_dir>/tools/inca/files
VERIUSER_C = $(NOVAS_HOME)/share/PLI/nc_xl/SOLARIS2/veriuser.c
PLI_OBJECTS = $(NOVAS_HOME)/share/PLI/nc_xl/SOLARIS2/pli.a
> make -f Makefile.nc static
New static executables will be created for ncsim and ncelab
Use these new static executables
> path = (<location of static executables>) $path)
VHDL
Dynamic linking
* Compile novas.vhd found in <Novas_install>/share/PLI/nc_vhdl/SOLARIS2
* Add in your vhdl code: use work.novas.all;
* setenv LD_LIBRARY_PATH <Novas_install>/share/PLI/nc_vhdl/SOLARIS2
If you need to generate your own compiled library the required files are novasfmi.c, novascfc.c and novas.a. They are located at: <Novas_install_dir>/share/PLI/nc_vhdl/SOLARIS2
* setenv LD_LIBRARY_PATH <Novas_install>/share/PLI/nc_vhdl/SOLARIS2/boot
ncelab -f run.f -access+r +loadfmi debfmi:debfmi_boot
Static Linking
Mixed Language Design
Dynamic linking
* Compile novas.vhd found in <Novas_install>/share/PLI/ldv4.0_vhpi/SOLARIS2
* setenv LD_LIBRARY_PATH <Novas_install>/share/PLI/ldv4.0_vhpi/SOLARIS2
If you need to generate your own compiled library the required files are novasfmi.c, novascfc.c, pli_body.o and veriuser.c. They are located at: <Novas_install_dir>/share/PLI/ldv4.0_vhpi/SOLARIS2
* Compile novas.vhd found in <Novas_install>/share/PLI/ldv4.0_vhpi/SOLARIS2/boot
* setenv LD_LIBRARY_PATH <Novas_install>/share/PLI/ldv4.0_vhpi/SOLARIS2/boot
ncelab -f run.f -access+r -loadfmi debfmi:debfmi_boot à If Top Level is VHDL
ncelab -f run.f +debug -loadpli1 debpli:debpli_boot à If Top Level is Verilog
Example Use Model
Verilog
Add the following in your Verilog code[1]:
initial begin $fsdbDumpvars; end
> ncverilog +access+r +debug -f run.f
OR
> Debussy -f run.f > verdi -f run.f
VHDL
Add the following in your vhdl code: process
begin
fsdbDumpfile("vhdl.fsdb");
fsdbDumpvars(0, "system");
wait ;
end process;
> ncvhdl -work WORK -f run.f
> ncelab -access +r work.system:blk
OR
> ncsim work.system:blk -input stop.do
Example stop.do File: call fsdbDumpfile nc_vhdl.fsdb
call fsdbDumpvars 0 :
run 12500 NS
exit
> vhdlcom -f run.f
> debussy -lib work -top system > verdi -lib work -top system
Mixed
begin
wait ;
end process;
Add the following in your Verilog code:
> ncvlog -work WORK -f run.f
> vericom -f run.f (verilog files only)
> vhdlcom -f run.f (vhdl files only)
For Debussy/Verdi Interactive Mode Simulation
In Novas GUI select the appropriate simulator, for example:
nTrace -> Tools --> Option --> Preferences ---> Simulator : NC-VHDL
Executable : ncsim
Run the simulation: nTrace -> Tools --> Interactive Mode ---> Run
Examples for dumping from Debussy/Verdi command line :
> call fsdbDumpvars
> run 12500 ns
> exit
Can also use options in GUI mode in Debussy/Verdi :
nTrace -> Debug ---> User Defined Commands
Dumping from NCSIM GUI
On the NCSIM GUI command line, you can type fsdb command as follows:
> call fsdbDumpfile {"test.fsdb"}
> call fsdbDumpvars 0 {"system"}
--> 0 : level , which specifies how many levels of hierarcy to dump for the subsequent scope
--> system: module / variable , gives either the module scope / variable that specify the objects to dump
