[SOLVED] [HELP] Number of Bits vs. Number of Array [VHDL]
TuAtAu
Jupiital
Hi guys, this is the problem that I face.
I declare a std_logic_vector
e.g.
entity:
PORT1_IN : in std_logic_vector(31 downto 0);
-- means I got 32 bits on a port
--then
--i wish to choose the number of bits instead of array, how do I do it.
e.g.
variable COUNTER : integer range 0 to 16;
COUNTER := COUNTER +1;
PORT1_IN(COUNTER) <= '1'; -- <-- If i do like that, it assume that I am choosing the Array!! not BITS! so i got error on Index value(s) does not match array range, simulation mismatch when SYNTHESIS. SOS, I am run out of ideas and I search google already.. no solution yet.
---------- Post added at 17:28 ---------- Previous post was at 17:13 ----------
For edition
I want to check in conditional :
If (PORT1_IN(COUNTER) = '1') then --This is error because it treat my PORT1_IN is an array and it is choosing the "COUNTER"th elements.. But what I want is vector
So how do I edit to make it to choose VECTOR instead of ARRAY?
I'm assuming the assignment to port1_in is the mistake, as you are attempting to drive a value onto the input port. While VHDL does support multiple drivers on the same signal, it generally is a mistake.
As for your error, I'm not sure. possibly it is an issue with you synthesizer.
edit -- the "error" probably should have been a warning, as sim-mismatches often are. The issue probably is that the variable infers a 5b value that, in implementation has a range of 0 to 31. This is because you have 17 values that the integer can take -- 0 to 16.
Reactions: TuAtAu
    TuAtAu
YES! permute you are right,
after i change my COUNTER to 32 -- 0 to 31
it solve the warning, BUT
my COUNTER is also use on another port which only has
R_IN: out std_logic_vector (15 downto 0);
So if I solve the PORT1_IN error by change to int32, the R_IN(COUNTER) <= '1'; mismatch again...
any win-win situation? to match both ?
---------- Post added at 18:11 ---------- Previous post was at 17:57 ----------
SOLVED!!
Thanks permute~! your reply really put me in the right rail in troubleshooting.
COUNTER : integer range 0 to 31
R_IN(conv_integer(conv_unsigned(COUNTER,4)))) <= '1'
working fine!
i'm pretty sure the synthesizer also accepts R_In(counter mod 16)
likewise, for sim, you probably need to do counter := (counter +1) mod 32;
