Help needed with USB interfacing for PIC18F4550
maniyuri
Newbie level 6
islamabad
Hi all,
I have tried using the USB example code from the library of MikroC with PIC18F4550 but it is not working. It gives an error :Main function not defined.
unsigned char readbuff[64] absolute 0x500;   // Buffers should be in USB RAM, please consult datasheet
unsigned char writebuff[64] absolute 0x540;
char cnt;
char kk;
void interrupt(){
   USB_Interrupt_Proc();                   // USB servicing is done inside the interrupt
void main(void){
  ADCON1 |= 0x0F;                         // Configure all ports with analog function as digital
  CMCON  |= 7;                            // Disable comparators
  HID_Enable(&readbuff,&writebuff);       // Enable HID communication
  while(1){
    while(!HID_Read())
    for(cnt=0;cnt<64;cnt++)
      writebuff[cnt]=readbuff[cnt];
    while(!HID_Write(&writebuff,64))
Please help me out. I am totally new to USB interfacing. If there is some material that you could refer, it would be of great help.
I also had some other doubts. What is the value in front of the first two lines (absolute 0x500, absolute 0x540). Any help will be greatly appreciated.
Regards.
Looks to me like your "main" should be called "Main"
absolute address is to force where processor puts the array--at absolute addr 0x500 in usb memory
