Help Needed for VHDL expression Error
preet
Full Member level 1
signal cc_c : std_logic;
variable right_operand : word;
variable tmp_result : unsigned(word'length downto 0);
tmp_result := ('0' & GPR_r1) + ('0' & right_operand)+ resize(unsigned'('0' & cc_c), word'length + 1);
ERROR:HDLParsers:827: The above expression can not be qualified by type unsigned
ERROR:HDLParsers:3324: IN mode Formal NEW_SIZE of resize with no default value must be associated with an actual value.
Please guide me for the above error
Warm Regards
subtype word is unsigned(31 downto 0);
hi..
in resize(unsigned'('0' & cc_c)
cc_c is std_logic
tmp_result is unsigned
weather it matches both types??
well its my question.
sanju, that is not the problem. The unisnged' is a qualifier to tell the compiler it's an unsiged.
Preet - the 'length attribute is not defined for types. use right_operand'length instead.
Am more interested on 2nd warning:
Can you show the part you instantiate & declare "resize"? Thanks
dear childs
both the error are pointing to same statement
Just an observation, the code compiles without errors in Altera Quartus, with IEEE.numeric_std.all imported for resize().
Dear FvM,
Will get back to you after synsthesizing thru Quartus
Thanks and Regards
Preet
