Help needed for curve fitting,i need to plot a equation T=k*I^n in matlab
singh1
Newbie level 2
Hi, I need to implement a equation for a dc motor in matlab. The eq is T=K*I^n . T is torque and I is current . I have a set of values as inputs for T and I, so, i need to find K and n at the output. Curve fitting has to be used for it.
I want the program code for it in matlab which could generate a curve and give K,n as the output.
Eagerly waiting for reply!!!
Thanks in anticipation!!!!
You can use Least mean square fitting algorithm
Search for LMS algorithm in matlab
also I think poly2fit is there in matlab toolbox which you can make use of
Thanks & Regards
M Kalyansrinivas
