I'm sorry for bothering you.
I'd like to simulate the following structure (see figure):
a) A 3mm-diameter loop receiver is placed on a small substrate.
b) The receiver and the substrate are then put in a plastic closed-end cylindrical tube (5mm diameter, 0.5mm thick).
c) the excitation-source is placed outside the cylindrical-tube, near the loop. The 100mW excitation can be: plane-wave or a dipole.
d) Is it practical to add lump component to the structure and still able to simulate it fast using A-Designer?.
I included the picture file and the project-file (Ansoft Designer). Could you please fix this file for me (in HFSS or Designer).
Thank you so much.
