Help need how to remove detected error in ADS2009
btv_murthy
Full Member level 3
Full Member level 3
BANGALORE
www.edaboard.com
Dear Sir,
I am new learner to ADS2009 simulation sofware, I have designed the nonlinear device LNA. I have created the nonlinear device model using datasheet of AVGO ATF34143. I used transistor as ANGLOV model IN ADS2009 and later added the input and output matching circuit. when I simulated , I got the following error.
"ANGLOV1 is an instance of undefined model of ANGLOVM1"
Can you anybody try help me to remove this error. I am attaching the following file
Hello,
maybe next time check the image quality, it is hard to see something.
Your ANGLOV1 is just a symbol with paramaters, you have to place the model symbol of ANGLOV1, which is called ANGLOVM1!
