HELP need c guru : extern variable declaration in data.h
coolhand21
Junior Member level 3
Hi I would like to declare a variable in a data.h and be able to use in other modules.c
data.h
#ifndef _DATA_H_
#define _DATA_H_
int foo = 10;
#endif
#include "data.h"
extern int foo;
void main
foo = 12;
test();
#include "data.h"
extern int foo;
test()
foo = 1+ foo;
my compiler complains multiple defintions
What i'm I doing wrong
thanks cool
blind_man
Member level 3
Romania
data.h
#ifndef _DATA_H_
#define _DATA_H_
extern int foo;
#endif
#include "data.h"
int foo = 10;
void main
foo = 12;
test();
#include "data.h"
test()
foo = 1+ foo;
g_shyam1682
Full Member level 4
Udaipur-Rajshan-India
Hi friend
you don't declare variable in Header file
Instead of
you can do this
int foo = 10;
void main
foo = 12;
test();
extern int foo;
test()
foo = 1+ foo;
Best of Luck
