library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity dcounter is
port (
rst : in std_logic;
clk : in std_logic;
ld : in std_logic;
din : in std_logic_vector(7 downto 0);
pulse : out std_logic);
end dcounter;
architecture behave of dcounter is
signal count : std_logic_vector(7 downto 0);
signal count_nx : std_logic_vector(7 downto 0);
begin -- behave
with (count_nx /= "00000000" and count = "00000000") select
pulse <= '1' when true,
'0' when others;
process (clk, rst)
begin -- process
if rst = '1' then -- asynchronous reset (active high)
count <= (others => '0');
elsif clk'event and clk = '1' then -- rising clock edge
count <= count_nx;
end if;
end process;
process (count, ld)
begin -- process
if ld = '1' then
count_nx <= din;
else
count_nx <= count - 1;
end if;
end process;
end behave;
