Microphone Network
Hi guys,
I would like to implement a number of microphone terminal which would share the same amplifier box. Only one microphone can be allowed to operate at a time through a switch or something like that. I'm not sure what signal form to be transmitted through the cable (CAT5 most probably) from the microphone to the amplifier. I'm aware that if I were to create a differential signal from the microphone input signal, only noise can eliminated but other contamination such as frequency shift cannot be avoided. Furthermore, the length of cable can be as far 50 feet which would results in great amount of lost.
One more thing, is there any CMOS IC that takes in analog signal and works as decoder at the amplifier end in order to allow certain microphone terminal.
Thank you very much.
