Help me with my C code - error: $myrandom is not defined
tarkyss
Full Member level 6
Full Member level 6
China
%mti_home%
I wrote a simple c program
#include "./veriuser.h"
#include "acc_user.h"
#include "stdio.h"
#include "stdlib.h"
#include "time.h"
int myrandom() {
time_t *nowtime;
time(nowtime);
srand((*nowtime));
printf("the time is %d\nthe random is %d\n", (*nowtime), rand()%128);
s_tfcell veriusertfs[] = {
{usertask, 0, 0, 0, myrandom, 0, "$myrandom"},
{0} // last entry must be 0
when running gcc and ld, no warning no error
but when i run
vsim -c test -pli myrandom.sl
it said, system task $myrandom is not defined.
why?
Re: PLI problem
Checkout the following code .....
filename: testme.c
#include "vpi_user.h"
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
void myrandom() {
 time_t *nowtime;
 time(nowtime);
 srand((*nowtime));
 io_printf("The time is %d\nthe random is %d\n", (*nowtime), rand()%128);
// Associate C Function with a New System Task
void registermyrandom() {
  s_vpi_systf_data task_data_s;
  p_vpi_systf_data task_data_p = &task_data_s;
  task_data_p->type = vpiSysTask;
  task_data_p->tfname = "$myrandom";
  task_data_p->calltf = myrandom;
  task_data_p->compiletf = 0;
  vpi_register_systf(task_data_p);
// Register the new system task here
void (*vlog_startup_routines[ ] ) () = {
   registermyrandom,
   0  // last entry must be 0
verilog code : test.v
module test();
   initial begin
      $display ("Runing PLI task now....");
      #10;
      $myrandom;
   end
endmodule // test
run following commands....
gcc -c -I${MTI_HOME}/include testme.c
ld -shared -o testme.so testme.o
vlog test.v
vsim -do run.do -c -pli testme.so work.test
I am using ModelSim SE VLOG 5.5d on Linux 2.4.20-28.7 x86 machine.
Hope this helps...
Re: PLI problem
register the PLI function in veriuser.c file, which will be used by the simulator at the time of linking. there will be one array named "veriusertfs" in that file. there we need to add an entry regarding the pli fn.
PLI problem
nand_gates
thanks, but when i run
the following is displayed
testme.c: In function `registermyrandom':
testme.c:18: warning: assignment from incompatible pointer type
Re: PLI problem
Change this
void myrandom()
to
int myrandom()
PLI problem
nand_gates thanks
now, gcc and ld is correct
but when i run
vsim -c -pli testme.so work.test
and then
run 1000
# Runing PLI task now....
# ** Fatal: (SIGSEGV) Bad pointer access.
# Time: 10 ns Iteration: 0 Process: /test/#INITIAL#2 File: test.v
# Fatal error at test.v line 5
# Stopped at test.v line 5
Re: PLI problem
Check with this ....
Replace
int  myrandom()
with
PLI_INT32  myrandom()
For me its working ....
# 5.5d
# vsim -do run.do -pli testme.so -c work.test
# Loading ./testme.so
# //  ModelSim SE VLOG 5.5d Aug 17 2001 Linux 2.4.20-28.7
# //  Copyright (c) Mentor Graphics Corporation, 1982-2001, All Rights Reserved.
# //                       UNPUBLISHED, LICENSED SOFTWARE.
# //            CONFIDENTIAL AND PROPRIETARY INFORMATION WHICH IS THE
# //          PROPERTY OF MENTOR GRAPHICS CORPORATION OR ITS LICENSORS.
# //  Copyright (c) Model Technology Incorporated 1990-2001, All Rights Reserved.
# Loading work.test
# do run.do
# The time is 1138003341
# the random is 62
Hope this time it works!!
PLI problem
nand_gates
thank you very much
it can not work yet, the error message is the same with the previous
do you think what is the possible reason? the env conf ?
Re: PLI problem
Which modelsim version you are using??? on which platfoem and what OS with version??
PLI problem
my os is sunos5.8
and the version of modelsim i tried are 5.8b, 6.1a, and 6.1c
