milan.rajik
Banned
Please help me with MAX7219 code. I want to print floating point values on MAX7219 but it is not printing.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 // LCD module connections sbit LCD_RS at LATB4_bit; sbit LCD_EN at LATB5_bit; sbit LCD_D4 at LATB0_bit; sbit LCD_D5 at LATB1_bit; sbit LCD_D6 at LATB2_bit; sbit LCD_D7 at LATB3_bit; sbit LCD_RS_Direction at TRISB4_bit; sbit LCD_EN_Direction at TRISB5_bit; sbit LCD_D4_Direction at TRISB0_bit; sbit LCD_D5_Direction at TRISB1_bit; sbit LCD_D6_Direction at TRISB2_bit; sbit LCD_D7_Direction at TRISB3_bit; // End LCD module connections #define Data7219 RD0_bit #define Load7219 RD1_bit #define Clk7219 RD2_bit const unsigned char Font_B[16] = {0x7e,0x30,0x6d,0x79,0x33,0x5b,0x5f,0x70, 0x7f,0x7b,0x77,0x1f,0x4e,0x3d,0x4f,0x47 }; unsigned long value; unsigned char dpset = 0, dp; void Send7219 (char,char); void Send7219byte(char); void MAX7219init(); void Display(float); char myStr[] = "230.14592"; double adcVal = 0.0, prevVal = 0.0; void main (void) { TRISA = 0xFF; TRISB = 0x00; PORTB = 0x00; LATB = 0x00; TRISD = 0x00; PORTD = 0x00; LATD = 0x00; ANSELA = 0x01; ANSELB = 0x00; ANSELC = 0x00; ANSELD = 0x00; ANSELE = 0x00; CM1CON0 = 0x00; CM2CON0 = 0x00; LCD_Init(); LCD_Cmd(_LCD_CURSOR_OFF); LCD_Cmd(_LCD_CLEAR); MAX7219init(); while(1) { //adcVal = ADC_Read(0); //adcVal = adcVal * 300.0 / 1023.0; //if(prevVal != adcVal) { Display(230.45698); prevVal = adcVal; //} } } void MAX7219init() { Data7219 =0; Load7219 =0; Clk7219 = 0; Send7219(0x09,0x00);//Decode Mode Send7219(0x0A,0x05);//Brightness Send7219(0x0B,0x07);//Scan limit Send7219(0x0C,0x01); Send7219(0x0F,0x00); } void Send7219(char Digit,char Data) { Send7219byte(Digit); Send7219byte(Data); Data7219=0; Load7219=1; Delay_us(20); Load7219=0; } void Send7219byte(char byte) { unsigned char i; for(i=0; i<8; i++) { if(byte & 0x80) Data7219=1; else Data7219=0; Clk7219=1; Delay_us(20); Clk7219=0; byte<<=1; } } void Display(float My_number) { unsigned char dispskip; // add 1 if "." found within string unsigned char i, j, string[23]; FloatToStr(My_number, string); //Convert float value to string Ltrim(string); //remove spaces padded to left of string i = 0; //check if there is a decimal point while(string[i]) { if(string[i] == '.') {dp = 1; break; } else dp = 0; i++; } i = 0; //if there is decimal point truncate the string after 2 places after decimal point if(dp) { while(string[i] != '.')i++; i++; i++; i++; string[i] = '\0'; } LCD_Out(1,1,string); dispskip = strlen(string) - 1; if((dispskip >= 8) && (dp))dispskip = 8; if(dispskip >= 8)dispskip = 7; for(i = 0; i <= dispskip; i++) { if((string[dispskip-i] <= 0x39) && (string[dispskip - i] != '.') && (dpSet == 0)) { Send7219(i+1, (Font_B[string[dispskip-i] - 0x30]));//0-9 j++; } if(string[dispskip-i] == '.'){//0x20 is ASCII " " dpSet = 1; i++; } if(dpSet) { Send7219(i+1, (Font_B[string[dispskip-i + 8] - 0x30]));//0-9 j++; dpSet = 0; } } for(i = j + 1; i <= 8; i++) { Send7219(i, 0); } }
