Help me with Keil assembler code in asm
pisoiu
Advanced Member level 3
Romania
keil related question
I am stuck from hours in this stupid keil assembler directives trying to solve a problem, but nothing so far. Here is what I want to do, maybe one more experienced than me can help. All is written in asm.
My device is 51 based, and it has an internal code memory(2k) and external eeprom memory (4k) for constants. The main module needs data (which are mainly ascii strings) from that memory using i2c bus. Those data are defined in external memory in a separate .asm file with:
label: DB 'blablabla'
But in the main code I need pointers to address them and for that I need to exchange labels between modules, in order for MOV DPTR,#label to point to correct address of 'label' in the other module. Let's say I have code.asm the file with main code, and i2c.asm the file for external data. I have managed so far to solve correct pointing address for 'label', but the problem is at the output. I need 2 separate .hex files, one with code and one with content of i2c memory, both starting at addres 0. So far I only got one .hex file at output, with the content of both (code and i2c) files, overlapped at 0. Any ideas? Thanks very much,
/pisoiu
C-Man
Re: keil related question
I have done something similiar this way:
when creating the eeprom with your messages also create a table with the adressess and put this table starting at a known adress at the begin (or at the end) of your eeprom.
Number your messages like 0, 1, 2, 3 ...
Whenever you want to get a message get its number, multiply by two, read its adress from your eeprom and use this adress to get your message.
The only disadvantage of this method is that you need more space in eeprom and also you need a little longer to get each message and if you change your messages you must remember to update your message numbers.
hope this helps and best regards
pisoiu
Romania
Thanks. It is a good trick, and if I remember correctly it is called URI scheme (Uniforme Resource Identifyer), and it is implemented in http/tcp/ip software implementation for scenix-ubicom microcontrollers. But I think somehow this can be done with assembler directives. For many embedded system developers I think is a common practice to keep non-code data such as strings for various peripherals (ex. gsm at initialisation commands) out of their main code memory, which is often a tight space in embedded design. Somehow this can be done....
/pisoiu
svicent
Full Member level 6
If you need 2 separate .hex files, you will need two projects, one with code (main.asm) and one with content of i2c memory (i2c.asm).
Regards, svicent
fireplus
Full Member level 3
this is the solution :
1- creat file and save it as i2c.asm
2-write in this file all the routines of the i2c eeprom
as :
read_add:
mov r1,A ; a have the address want to read
ret
3-after you write all your routines creat anthoer file called it Main.asm
4- in the main write the following :
org 00h
ljmp start
org 30h
#include <i2c.asm>
start:
mov A,#02h
lcall read_add
ljmp start
end
sorry for my bad english :oops: ,i hope that help you
bye
Fire in the Wire :sm2:
l
