Help me with changing AVR code for a proper PIC
crocklip
Junior Member level 1
AVR code to PIC
I recently came across a schematic in PCS's schematic vault named "digital guitar tuner". The code included was written for an Atmel 2323 chip. Now heres the thing: I want to use the same idea for a PIC16f877a chip so I have tried to change all the instructions to suit a PIC orientated program! am I mad?
I used the hex file from a PIC compiler that I'm using and simulated the program using 'PIC simulator IDE' and not very surprisingly it didnt work. I would probably have died of shock if it did!
Anyway I have attached the original code and the changed code. I would be extremely grateful if someone could point out where I've gone wrong. Maybe something to do with the position in the program of the overflow accumulator(line 80)?
Now as ye can probably tell from the code that programming isn't my strong point so apologies in advance!
Hope to hear from someone soon!
Dave
//original code
Simple Digital Guitar Tuner
version 1.0 2001-02-12 jesper
PIN assignements on the 2323
PB0 High LED
PB1 Input pin
PB2 Low Led
#include <io.h>
#include <signal.h>
#define F_CPU 11059200 // CPU clock frequency
#define PRESCALER 64 // CPU prescaler value
#define BASE_FREQUENCY (F_CPU/PRESCALER) // counter frequency
#define TUNING_FORK_A 440.0 // "base" A
#define NOTE_DIFF 1.05946309436 // the 12'th root of 2
#define E_STRING 164.81 // top string (1)
#define A_STRING 220.00
#define D_STRING 293.66
#define G_STRING 391.99
#define B_STRING 493.88
#define EH_STRING 659.26 // bottom string (6)
// The guitar note span
//EF G A BC D EF G A BC D E
//1 2 3 4 * 5 6
unsigned int Center_Count[] = //look up table;.
BASE_FREQUENCY/EH_STRING, // High E
BASE_FREQUENCY/B_STRING, // B
BASE_FREQUENCY/G_STRING, // G
BASE_FREQUENCY/D_STRING, // D
BASE_FREQUENCY/A_STRING, // A
BASE_FREQUENCY/E_STRING, // Low E
unsigned int Transition_Count[] = //look up table
BASE_FREQUENCY/(B_STRING+(EH_STRING-B_STRING)/2), // E to B
BASE_FREQUENCY/(G_STRING+(B_STRING-G_STRING)/2), // B to G
BASE_FREQUENCY/(D_STRING+(G_STRING-D_STRING)/2), // G to D
BASE_FREQUENCY/(A_STRING+(D_STRING-A_STRING)/2), // D to A
BASE_FREQUENCY/(E_STRING+(A_STRING-E_STRING)/2), // A to E
volatile unsigned char count_hi; // overflow accumulator
//timer 0 overflow interrupt
SIGNAL(SIG_OVERFLOW0)
count_hi++; // increment overflow count
// Main Lupe
int main(void)
unsigned int i;
unsigned int count;
// Initialize
cbi(DDRB, 1); // PB1 is input
cbi(PORTB, 1); // no pullups active
sbi(DDRB, 0); // PB0 is ouput, High LED
sbi(DDRB, 2); // PB2 is ouput, Low LED
outp(0x03,TCCR0); // set prescaler to f/64 (172.8 kHz @ 11.0592 MHz)
sbi(TIMSK,TOIE0); // enable interrupt on timer overflow
asm volatile ("sei"); // global interrupt enable
// Let things loose
while (1) // loop forever
count = 0; // clear sample count
loop_until_bit_is_set(PINB,1); // wait for something to happen
// got a high edge
// start sampling
outp(0,TCNT0); // clear counter
count_hi = 0; // clear hi count
// sample loop
for (i=0;i<32;i++)
while (bit_is_set(PINB,1)) // ignore hi->lo edge transitions
if (count_hi > 80) // skip if no edge is seen within
break; // a reasonable time
while (bit_is_clear(PINB,1)) // wait for lo->hi edge
count += (count_hi << + inp(TCNT0); // get counter value
if (count_hi > 80) // skip if counter has accumulated a
break; // too high value
// initially turn off both leds
sbi(PORTB,0);
sbi(PORTB,2);
if (count_hi <= 80) // if count is reasonable
count = count >> 5; // average accumulated count by dividing with 32
// now we have to find the correct string
// go through transition frequencies
for (i=0;i<sizeof(Transition_Count)/sizeof(Transition_Count[0]);i++)
if (count < Transition_Count) // stop if lower than this transition count
break;
// i now holds the string index
// check the count for a match, allowing
// 1 extra count "hysteresis" to avoid too
// much LED flickering
if (count-1 <= Center_Count) // if count <= this string count
cbi(PORTB,0); // light "Too High" LED
if (count+1 >= Center_Count) // if count >= this string count
cbi(PORTB,2); // light "Too Low" LED
//Changed code
#include <pic.h>
#include <htc.h>
#define F_CPU 20000000 // CPU clock frequency
#define E_STRING 164 // top string (1)
//1 2 3 4 * 5 6
//if (TMR0IF = 1)
//count_hi++;
//} // increment overflow count
//TMR0IF = 0;
// Main Loop
int main(void)
unsigned int i;
unsigned int count;
if (TMR0IF = 1)
count_hi = (count_hi + 1);
TMR0IF = 0;
// Initialize
RD4 = 1;
TRISB = 0x02; // RB1 is input
RB1 = 0; // no pullups active
T0CS = 0; //enable TMR0
PS2 = 1; // set prescaler to 1:64 (For 2323 only: 172.8 kHz @ 11.0592 MHz)
PS1 = 0; // ' ' ' ' ' ' ' ' ' ' '
PS0 = 1; // ' ' ' ' ' ' ' ' ' ' '
PSA = 0; //SET PRESCALER TO TMR0
TMR0IE = 1; // enable interrupt on timer overflow
GIE = 1; // global interrupt enable
// Tune
count = 0;
while(1)
if(RB1 = 1)
break;
} // wait for something to happen
// got a high edge
// start sampling
TMR0 = 0x00; // clear counter
// sample loop
for (i=0;i<32;i++)
while (RB1 = 1) // ignore hi->lo edge transitions
while (RB1 = 0) // wait for lo->hi edge
count += (count_hi << + (TMR0); // get counter value
if (count_hi > 80)
RB0 = 0;
RB2 = 0;
break;
RB0 = 1; // light "Too High" LED
RB2 = 1; // light "Too Low" LED
if (count+1 == Center_Count) // if count = this string count
RB1 = 0; //EQUAL!
RB2 = 1;
Re: AVR code to PIC
i also came across same avr source for tuning my guitar. i don't have avr or pic. i want to implement on at89c51...so plz tell in where in the source file do i have to make adjustment in order to burn the code in at89c51 microcontroller?
thank you
Re: AVR code to PIC
here's the code for at89c51.
i use timer 1 to generate 173khz internal clock
i use the ckt and the code in proteus...the code didn't work even i gave exact frequecies for string from freq generator..
plz plz help me
Added after 15 minutes:
here's the code
//original code
PB0 High LED
PB1 Input pin
PB2 Low Led
#include <reg51.h>
sbit input=P1^1;
sbit led1=P1^0;
sbit led2=P1^2;
#define BASE_FREQUENCY (F_CPU/PRESCALER) // counter frequency 172800
//1 2 3 4 * 5 6
BASE_FREQUENCY/EH_STRING, // High E 262
BASE_FREQUENCY/B_STRING, // B 350
BASE_FREQUENCY/G_STRING, // G 441
BASE_FREQUENCY/D_STRING, // D 588
BASE_FREQUENCY/A_STRING, // A 785
BASE_FREQUENCY/E_STRING, // Low E 1048
void timer1_ISR (void) interrupt 3
count_hi++;
// Main Lupe
void main(void)
unsigned int i;
unsigned int count;
P1=0x00;
Set Timer1 for 8-bit timer with reload
(mode 2). The timer counts to 255,
overflows, is reloaded with 156, and
generates an interrupt.
Set the Timer1 Run control bit.
TMOD = (TMOD & 0x0F) | 0x20; /* Set Mode (8-bit timer with reload) */
TH1 = 250; /* Reload TL1 to count 100 clocks */
TL1 = TH1-1;
ET1 = 1; /* Enable Timer 1 Interrupts */
TR1 = 1; /* Start Timer 1 Running */
EA = 1; /* Global Interrupt Enable */
// Initialize
%cbi(DDRB, 1); // PB1 is input
%asm volatile ("sei"); // global interrupt enable
// Let things loose
//loop_until_bit_is_set(PINB,1); // wait for something to happen
if(input==1)
// got a high edge
// start sampling
//%outp(0,TCNT0); // clear counter
TL1=TH1-1;
// sample loop
for (i=0;i<32;i++)
while (input==1) // ignore hi->lo edge transitions
while (input==0) // wait for lo->hi edge
//count += (count_hi << + inp(TCNT0); // get counter value
count+=count_hi<<5;
TH1=250;
TL1=TH1-1;
if (count_hi>80) // skip if counter has accumulated a
//%sbi(PORTB,0);
led1=0;
//%sbi(PORTB,2);
led2=0;
if (count_hi<=80) // if count is reasonable
count=count>>5; // average accumulated count by dividing with 32
for (i=0;i<(sizeof(Transition_Count)/sizeof(Transition_Count[0]));i++)
if (count<Transition_Count) // stop if lower than this transition count
break;
if((count-1)>=Center_Count)
//count=count+0;
//%cbi(PORTB,0); // light "Too High" LED
led1=1;
if((count+1)>=Center_Count)
//count=count+0;
led2=1;
//%cbi(PORTB,2); // light "Too Low" LED
plz check for error and let me know
