Help me with calculation of SNR
bizoo
Member level 5
Hi
i need help regarding calculating SNR,
My signal is coming out of a RF receiver which demodulates it from higher freq to baseband,
the signal is noisy and i want to calculate its SNR,
i can generate the original received signal with simulations as well, or i can get the original transmitted signal form another chip(of same kind)
now how should i caluclate SNR, use the signal from simulations or use the one from the tx pin of receiver of the IC, and compare it with the noisy received signal.
Also there is this issue of how to get SNR by comparing a noisy signal with a noise free signal from the oscilloscope
any help is appreciated
br
Re: Calculation of SNR
you need to find the mean and variance from the received signal and calculate the SNR. That is fairly standard method.
Hope this helps
well actually
i thought of the same in the beginning, i was thinking about taking the ratio of mean of the signal to its std deviation as SNR but the signal is zero mean and SNR is in -db which doesnot make sense, as the signal sure looks alright with slight fluctuations though :s
bg
What is this document?
spam!!?
Guess you want to measure SNR at RF reciever output.
Measure power of signal at RF recvr output using some equipment, you get signal+noise power (x). Now switch off transmission and repeat, you get noise power(y). Assuming all noise is additive and uncorrelated to signal, calculate SNR as x/y - 1. Agree?
-b
not a bad idea,
but can You calrify why x/y-1, where did this -1 comes from,
and also, the approach i have taken is that i calculated the psd of the signal going out from the tx pin of transmitter chip,
then i went to the receiver chip in the other building and found the psd of the received signal, then :
SNR= max(PSD at tx pin)- max(PSD at receive pin) (db)
is this approach ok?
-1 comes from the noise variance..
Do not transmit anything..
find the power of the received signal which gives you the noise power NP.
Now transmit the required signal
The signal power SP is
SP=Total Received power(RP) -NP
SNR=SP/NP
=RP/NP -1
you method should work, but you have make some corrections
darock is, of course, correct, and so this has to be included into your calc, unless SNR is high.
secondly, PSD gives power at a certain frequency. Dont know why you take max. What max is this, is it maximum across frequency or max of different measurements done at different times?
Since we are required to find complete power, we sould sum up (integrate) PSD across all significant frequencies.
-b
Calculation of SNR
but if i can't get noise power(y),
and can get signal+noise power (x) only, how can i calc SNR???
actually i am getting same problem,
i can only access the signal once it has been converted back to baseband frequency, so if i stop trasnmissioon and monitor that prin, all i will get will be noise which has been passing through the AGC and will have same apparent power as the signal and this baffles me too,
how to get to noise power then?
Hi guys, there is a bit of blow here, the power meter i have been using has been erroneous, and it is giving big deviations from its previous values now
All i have the signals themselves inside the oscilloscope, and their PSD, is there a way of finding SNR with psd and not replying on these darned power meters
I assume you have samples of the received signal for a long duration (1000s of symbol periods). I also assume you can find the begining of the symbol period. Now average the symbols over a long period and then you should get the signal amplitude fairly accurately, since the noise should average out. Now knowing the signal shape, amplitude and period, you can find its power. You can now subtract the recieved power from the signal power and get the noise power.
This of course assumes noise is additive and uncorrelated to the signal.
-b
hello
can any1 help me
i'm using cadence spectre
how many cycles i must simulate ADC to calculate SNR!!!!!
& how to calculate SNR,SNIAD !!!!!
which function i should use psd or dft function in caluculator!!!!!
hello
can any1 help me
I have the same problem, can someone upload some tutorial documents related to calculator functioning in Cadence.
how to come to conclusion about input frequency of ADC?????????
how to select bin for FFT???????
how many cycles 1 shud simulate inorder to find noise shaping??????
