I want to build a simple antenna that can locate a transmitter without prior knowing where it is... Its probably located at a distance of a soccer field... What the type of antenna should i build?? Im just a beginner in this field.
Probably an antenna that has high directionality and high gain??
Maybe dipole, patch, horn. These are pretty basic to design and should work. Dipoles at high frequencies, above 7 GHz are not very pratical. Patches are simple to build if you have the materials and horns you can build from circuit board materials and will work fine for a small project.
It is for 2.45GHZ. Is Helical antenna a good design for this task? We do not need a wide bandwidth, just have to detect the signal clearly n search out where the signals coming from.
