[HELP ME] [VHDL Code] Clk floating problem
CyberBoy
Newbie level 3
Hi Guys, can anybody help me ???
I want to compile this modular project, with synplify I have make a synthesis of this code,but return me a WARNING ... clock and start as not used... :-/ WHY, I have connected all necessary (clk and start)
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
--library work;
--use work.all;
--  Uncomment the following lines to use the declarations that are
--  provided for instantiating Xilinx primitive components.
--library UNISIM;
--use UNISIM.VComponents.all;
entity top_cpu1 is
    Port ( clk : in std_logic;
           start : in std_logic;
           reg_a_out : out std_logic_vector(4 downto 0);
           reg_b_out : out std_logic_vector(4 downto 0);
           reg_c_out : out std_logic_vector(7 downto 0));
end top_cpu1;
architecture Behavioral of top_cpu1 is
component ram256x8 is
	Generic ( bits: INTEGER := 8;
			words: INTEGER := 256);
     Port (clk : in std_logic;
		 ram_mar : in std_logic_vector(7 downto 0);
           ram_in : in  std_logic_vector(7 downto 0);
		 ram_out: out std_logic_vector(7 downto 0);
           ram_we : in std_logic);
end component;
component pc_reg is
           pc_rst : in std_logic;
           pc_inc : in std_logic;
           pc_out : out std_logic_vector(7 downto 0));
end component;
component ir_reg is
    Port ( clk :in std_logic ;
    		 ir_in : in std_logic_vector(7 downto 0);
           ir_out : out std_logic_vector(7 downto 0);
           ir_we : in std_logic;
           ir_rst : in std_logic;
		 i_out : out std_logic_vector (3 downto 0));
end component;
component controlUnit is
--    Port ( u_inc : in std_logic;
--           u_rst : in std_logic;
--		 clk : in std_logic
--           pc_inc : out std_logic;
--           ir_we : out std_logic;
--           a_we : out std_logic;
--           b_we : out std_logic;
--           c_we : out std_logic;
--           ar_we : out std_logic;
--           addressB : out std_logic;
--           dataB0 : out std_logic;
--           dataB1 : out std_logic);
           istr_reg : in std_logic_vector (3 downto 0);
		 output_rom : out std_logic_vector (10 downto 0)
end component;
component c_reg is
    Port ( c_in : in std_logic_vector(4 downto 0);
           c_out : out std_logic_vector(7 downto 0);
           clk : in std_logic;
           c_we : in std_logic);
end component;
component data_bus is
    Port ( sel    : in std_logic_vector(1 downto 0);
    		 c_in   : in std_logic_vector(7 downto 0);
           mbr_in : in std_logic_vector(7 downto 0);
		  a_out  : out std_logic_vector(7 downto 0);
		 b_out  : out std_logic_vector(7 downto 0);
		 mbr_out: out std_logic_vector(7 downto 0));
end component;
component address_bus is
    Port ( sel : in std_logic;
    		 pc_in : in std_logic_vector(7 downto 0);
           mar : out std_logic_vector(7 downto 0));
end component;
component b_reg is
    Port ( b_in : in std_logic_vector(7 downto 0);
           clk : in std_logic;
           b_we : in std_logic);
end component;
component Alu is
    Port ( a_input : in std_logic_vector(4 downto 0);
           b_input : in std_logic_vector(4 downto 0);
           c_output : out std_logic_vector(4 downto 0));
end component;
component a_reg is
    Port ( a_in : in std_logic_vector(7 downto 0);
           clk : in std_logic;
           a_we : in std_logic);
end component;
signal clk1, NET1, NET2, NET3, NET4, NET5, NET6, NET7, NET8, NET9, NET10, NET11, NET12 : std_logic ;
signal BUS8_1, BUS8_2, BUS8_3, BUS8_4, BUS8_5, BUS8_6, BUS8_11, BUS8_12, BUS8_13  : std_logic_vector (7 downto 0);
signal BUS5_4, BUS5_5, BUS5_6 : std_logic_vector (4 downto 0);
signal BUS4 : std_logic_vector (3 downto 0);
signal BUS2_1 : std_logic_vector (1 downto 0);
begin
	  clk1 <= clk AND start;
	  BUS2_1 <= NET10 & NET11;
	  NET12 <= '1';
	  U1: pc_reg PORT MAP (clk => clk1, pc_rst => NET1, pc_inc => NET3, pc_out => BUS8_1);
	  U2: ir_reg PORT MAP (clk => clk1, ir_in => BUS8_4, ir_out => BUS8_2, ir_we => NET4, ir_rst => NET2, i_out => BUS4);
	  U3: controlUnit PORT MAP (clk => clk1, u_inc => NET12, istr_reg => BUS4, output_rom(10) => NET1,output_rom(9) => NET2,output_rom(8) => NET3,output_rom(7) => NET4,output_rom(6) => NET5,output_rom(5) => NET6,output_rom(4) => NET7,output_rom(3) => NET8,output_rom(2) => NET9,output_rom(1) => NET10,output_rom(0) =>  NET11);
	  U4: alu PORT MAP( a_input => BUS5_4, b_input => BUS5_5, c_output => BUS5_6);
	  U7: a_reg PORT MAP( a_in => BUS8_12, a_out => BUS5_4, clk => clk1, a_we => NET5);
	  U6: b_reg PORT MAP( b_in => BUS8_13, b_out => BUS5_5, clk => clk1, b_we => NET6);
	  U5: c_reg PORT MAP( c_in => BUS5_6, c_out => BUS8_11, clk => clk1, c_we => NET7);
	  U8: ram256x8 PORT MAP( clk => clk1, ram_mar => BUS8_3, ram_in => BUS8_5, ram_out => BUS8_6, ram_we => NET8);
	  U9: address_bus PORT MAP( sel => NET9 , pc_in => BUS8_1, ir_in => BUS8_2, mar => BUS8_3);
	  U10: data_bus PORT MAP( sel => BUS2_1 , c_in => BUS8_11, mbr_in => BUS8_6, ir_out => BUS8_4, a_out => BUS8_12 , b_out =>  BUS8_13, mbr_out => BUS8_5);
end Behavioral;
Added after 2 hours 28 minutes:
In a VHDL project with a TOP fiel, can I have only input_top without output ???
Thanks
I think that this is my problem...
entity top_cpu1 is
end top_cpu1;
Are you sure of the syntex you've write
I'm learning VHDL-AMS
we've to write
" end entity --------"
no .. this is not a problem.. I have change it .. but I have the same problem...
Thanks
You mean that the entity shown is not the top, but there is something higher that instantiates your entity but does not have any outputs on the FPGA?
In that case, all VHDL logic will be optimised away and then the inputs will indeed be "unused".
If you don't need an output for the moment (while constructing the design) you can trick the synthesis tool by taking all internal outputs of your entity and making a "XOR" of all these functions, and sending it to 1 output. That way the synthesis tool can't optimise it away.
Another option is to look for your synthesis tool options to not optimize unused nets.
    CyberBoy
You have resoned .. .the problem was on missing output... Do you know if it's possible in Xilinx XST or Synplify ... Disable this optimisation ???
thanks
I have looked on the Xilinx website but didn't find it. I remember a MAP option to avoid optimizing unused logic. You need both Xilinx MAP/PAR options and synthesis tool options to avoid losing all logic in one of the implementation steps.
That's why I recommend the XOR solution, which is easier because the synthesis tools cannot optimize it away anymore no matter what the options are.
Xilinx also recommends it in Answer Record 16493:
Here they talk about unused inputs, but in your case you also want to preserve all internal logic. So you need to connect the XOR dummy output to the final outputs of your internal entities (the ones that would normally go to the chip's output). This way no matter what the synthesis options are, the intermediate logic and inputs cannot be optimized away because the synthesis tool knows they are required for the XOR output.
Why don't you have real outputs in your circuit? Is it still under construction and will you do the outputs later on?
