help me to kill the process (cadence)
birdiee470
Junior Member level 3
cadence + kill
can anyone help me..i cannot edit my design (cadence) after my pc is hang,, after restart my pc i cannot edit my design,,anyone can help me what is the command for kill this process..i`ve try kill -9 PID but it cannot work..
kill cadence process icfb
Do you mean your design can only be opened with read-only mode? You don't need to kill some process. It is because the lock file is not be deleted automatically before. Go to the directory of your design. For example, if your design is "myLib top schematic", cd to the top/schematic directory under myLib's path. Then delete the "*.cdslck" file.
Alternatively, you can use find command to delete all "*.cdslck" file:
find myLib -name '*.cdslck' -exec rm {} \;
where myLib is the path of your lib.
kill cadence
use to list all your process first: ps -ef |grep [name]
next kill the process: kill -9 [process_name]
Hope this helps
