Re: GLCD problem
Hello!
There are many reasons that may result in this.
- Are you sure the LCD works?
- Are you sure of your connections?
I would start by verify one by one.
For instance, use an oscilloscope, and issue a reset at the start of your
program, and verify that the reset in your software is actually connected
to the physical reset. Do the same with chip select, register select, etc…
- Are you sure of your SPI port setting? Put a scope on clock and data, and
send a byte which is easily identifyable (example 0x55 or 0xAA). Look at
the data ouput vs clock output.
- Are you sure of your initialization sequence?
Once the above works perfectly, verify your initialization sequence.
Try to change the contrast, try to change other parameters, for example bias,
etc… I would be surprised if you cannot make it work like this. But it's like
anything else, you have to put effort in it.
Dora.
mostafa ewaiha said:
hi all
I'm in the graduation project and I've a problem with GLCD 128*64 based on KS108 by using PIC32MX360F256L --- MPLAB "C32"
every time I code PIC, the GLCD doesn't respond any signal
please, I need help
Added after 28 minutes:
Can someone suggest me example or where to study an application note.
